DB9 Headliner
Old Nov 16, 2014 | 12:40 PM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
DB9 Headliner
So I've had this idea about doing some custom work on my headliner and I'm finally going to be moving forward with the project since winter has set in here in the Midwest and I get to just stare at my car for the next 6 months or so..
I want to do a diamond quilted pattern in the headliner. Finding the material was the biggest challenge so far. My car is Obsidian black with Tailor Grey alcantara headliner etc. I thought I could find an alcantara "type" material that would match (sensuede, etc) but nothing I could find from numerous manufactures in the U.S matched exactly. So I wound up buying the material from the company in the UK that supplies Aston Martin to guarantee I got the exact same material. I'd list the name and contact information of the company but I'm pretty sure that would violate the forum rules, but if anyone is interested I'd be happy to share so please feel free to PM me. They were very easy to work with and even sent me samples free of charge to assure me the match would be exact. Really great people.
My concern now is removing the factory headliner. Does anyone have any tips or suggestions regarding this? It seems like I should just be able to pop loose the piece covering the inner "A" pillar and over the door glass area and the headliner should just pop out?? Any help or suggestions would be great.. Thanks in advance, and I'll be sure to share some pictures as the project moves along.
Eric
Old Nov 16, 2014 | 02:02 PM
CARAIBAM's Avatar
CARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of light
I just reglued my headiling as the foam had disintegrated under our wet and hot weather (Caraibbean island).
You will need to remove:
1-Instruments cap,unclip
2-Both lower panels of the dash, unclip
3-Glove box,unbolt, taking care not to break the rope retaining the glovebox
4-Air bag pannel, remove bolts from behind glovebox,then unclip gently as it is pre cut for air bag deployment
5-Driver side dash trim (the one with the air con vent) unclip
6-Passenger side dash trim,unclip + remove bolt (hidden by the air bag cover)
7- Front panels trim, unclip and bolts
8- The two arches, start by prising them at the rear where it slides under the leather trim working your way toward the front, it is a good idea to order new trim studs.
9- Interior mirror,sunshades and front headling pannel.
Now you should be able to slide the headling through the door after tilting the seats.
Long but not too difficult job,I treated all leather panels prior to reffing with Gliptone.
Could you please PM the company name in the UK and if you have a contact name.
Few photos on our French forum: http://astonpassion.com/index.php?/t...el+%2Bpavillon
but you need to register to see them
Old Nov 16, 2014 | 10:17 PM
karlfranz's Avatar
FYI Gulf Fabrics in Tampa, Florida is the only authorized distributor of Alcantara in the USA. You can do a web search to find them. Ask for Dino or Barbara and they can send you a small sample so you can match the color to your car. They carry all colors and usually have them in stock.
Old Nov 17, 2014 | 11:55 AM
Thanks for the help! I tried viewing the images and I created an account and it won't let me open them for some reason.. I'll send you a PM with the contact info you asked about. Thanks again for the information.
Old Nov 17, 2014 | 12:02 PM
Thanks for the reply Karl. I actually did contact them and they sent me samples but none of which were a match. Not sure if maybe they just don't "stock" that color any more (my car is 2005) or what??
Old Nov 26, 2014 | 06:02 PM
CARAIBAM's Avatar
Eric, did you receive my emails with the photos?
Old Nov 27, 2014 | 09:39 PM
I got one and I sent you a reply.. You didn't get? Thanks for the pictures. My headliner is out and at the upholstery shop right now. It's supposed to be ready next week. I'll post some pictures once I get it back installed. Thanks again for the help!
Old Nov 28, 2014 | 03:40 AM
CARAIBAM's Avatar
no I didn't receive your reply, hope the pictures helped.
Old Nov 28, 2014 | 02:06 PM
A tremendous help! Thanks again for taking the time to send them. You got my email with the contact information for the Alcantara supplier correct?
KOCF
Jul 18, 2019 03:09 AM
airbusdrvr
Dec 27, 2015 07:43 PM
Ekaplan1020
Oct 2, 2015 07:39 AM
Collinsjd
Sep 29, 2015 09:38 AM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
