Fuse 22
Old Dec 5, 2014 | 08:13 PM
Jeff1smith's Avatar
Jeff1smith is infamous around these parts
Fuse 22
Traded in my 2006 Vantage for a 2009 DB9. I want to pull the 22 fuse for the sound
On my Vantage looking at the fuse panel in the boot, there were two fuses missing. The bottom and fourth from the bottom on the inside row.
Does anyone know which fuse will disable the baffles on the DB9 and it's location?
Jeff
Old Dec 5, 2014 | 08:34 PM
kensilver's Avatar
kensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud of
Hey Jeff,
User CP > Edit Signature.
Old Dec 6, 2014 | 07:46 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
AFAIK it's still fuse 22 for a 2009 DB9. Should be in the row closest to the front of the car (farthest from where you're standing), left side of the fuse box.
Old Dec 6, 2014 | 01:56 PM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
Disappointed in Fuse 22 sound difference
So - perhaps a bit foolishly - I decided to install a remote switch for fuse 22, together with the changeover relay as detailed in a brilliant write-up on Pistonheads, without first simply listening to my '06 DB9 Volante with the fuse pulled.
The installation was painless, but when I pushed the button on the remote I was very surprised by how little difference it made. Yes, I could hear a little more low-midrange rumble at startup, but the difference was so small that I thought I must have done something wrong. I know it wasn't just my hearing, because my wife didn't even remark on the change.
I then removed the remote setup and re-started the car with just fuse 22 pulled, and it sounded just like when I activated the remote. In other words, just a subtle boost in the low-mids.
Is this the just nature of DB9s of my car's era? Is all the fuse 22 removal glory reserved for V8s?
Old Dec 6, 2014 | 09:07 PM
Jeff1smith's Avatar
Thanks for the feedback. Sounds like it is a non starter. I still would like to "hear," for myself. I looked in the boot on the right rear side for the fuse box, where it was on the Vantage. Didn't see it there on the DB9. Anyone know where the fuse box is located on the DB9?
Old Dec 6, 2014 | 09:23 PM
zuman's Avatar
Fusebox location
In my '06, the fusebox with the correct fuse is on the DRIVER'S side of the trunk. In my Volante, there is a small "step up" on the far left trunk floor with a carpeted cover attached with Velcro. Peel up the cover, and underneath is a triangular Styrofoam holder with a few tools inside, and the fusebox is forward of that. In my car, Fuse 22 is the furthest left and forward, up against a relay. It's yellow-colored.
Old Dec 7, 2014 | 03:27 PM
Jeff1smith's Avatar
Thanks for the info. Just leaving in a cruise, I'll do it next week. Did you notice any change in the volume?
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
V565MAN
Oct 2, 2015 05:48 AM
gliozzi
Bentley
Sep 29, 2015 09:27 AM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
