Oil change
Old Dec 21, 2014 | 01:53 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Oil change
So. I just did my first oil change on the Vantage . Drained oil at all the points required ,new filter cleaned front and rear bypass screens etc . Had a B$&?#h of a time getting the screws out on the front screen . Ended up cutting a slot in the heads and using a super sized screwdriver to get them out . Now replaced with just regular 6mm bolts .
So my question is I cleaned the front and rear screen and was looking around admiring my work and checking for leaks after and noticed this in the pic .
Is the item in the centre of the shot another bypass screen or is it some kind of thermostatic bypass valve for the oil cooler . Does it need removal during regular oil changes ?
Old Dec 23, 2014 | 04:25 PM
Vantagelvr's Avatar
160 + views and no one knows what this is ?
Old Dec 23, 2014 | 06:58 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
what I do know, its not one of the screens or access points you need to worry about.
Old Dec 23, 2014 | 07:08 PM
Vantagelvr's Avatar
If I don't get an answer on here I will just open it up next oil change and figure it out myself . The cover looks identical to the screen covers . I like to get to know what stuff is and how it works .
Everything I learned about Healeys and rebuilding them is self taught . The Vantage is no different just more of a challenge .
Old Dec 24, 2014 | 12:11 AM
XWCGT's Avatar
open it up!! im curious too!
Old Dec 24, 2014 | 07:49 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Looking through the AM Workshop Manual, it appears that the object in question would be the oil thermostat housing.
FYI, there is about one quart/liter of oil trapped in the oil cooler and its associated lines which can't drain out. To remove it you either have to loosen one of the lines to the oil cooler or snake a small hose down through the oil reservoir and vacuum the oil out.
Old Dec 25, 2014 | 12:28 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Just went to the good book myself and Sir you are in fact correct. lubrication system page 3-2-14 says it is the thermostat housing.
Even more amaizing is how one is almost compelled to go and help a fellow AM owner when we have questions
I belong to a few forums (aviation, boring i know) and this is my the one i enjoy and value, so my thanks and Christmas wishes to the mods
Old Dec 25, 2014 | 12:55 AM
XWCGT's Avatar
I wonder why that screen or access port is not recommended to open and clean... maybe because its post filtered oil.... maybe its there to protect the engine if something downstream should break or come apart.
Old Dec 25, 2014 | 07:10 PM
djantlive's Avatar
Why does vantage have these screens to clean? I haven't had to do that on any other exotics that have dry sump. Or is this just extra work that no one else normally do for oil changes?
Old Dec 27, 2014 | 07:41 PM
DonL's Avatar
Only the 4.3 engines have the screens...when AM went to the 4.7 engine, they removed the screens and replaced them with drain plugs.
AFAIK, the screens were a "good idea" of a designer who may have had an prior issue with an engine problem that resulted in debris in the oil which the filter was unable to catch?
Speaking from ignorance with an educated guess .
Welcome to any other interpretations...
alwaysbored786
Apr 19, 2016 05:51 AM
4ocious
Sep 1, 2015 06:44 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
