question about removing rear rotors?
Old Jan 4, 2015 | 06:52 AM
boxercupdave's Avatar
boxercupdave has a spectacular aura aboutboxercupdave has a spectacular aura about
Hoping someone can point me to a link with info or can provide some additional info on removing the rear brake rotors?
Car has 30K miles and I'm installing my EBC pads but before I do I either want to clean up the original rotors or replace with new. I have the calipers off (emergency and brake) and the two countersunk retaining screws. The rotor seems to be on the hub very tight. I don't believe the hub/axle nut needs to be removed from images of replacement rotors as the rotor appears to slide over the flange that has the axle nut in the center of it.
Note: I've done brakes on my previous cars but a bit nervous about applying any force until I know exactly what's retaining the rotor on the V8V.
Old Jan 4, 2015 | 07:47 AM
telum01's Avatar
I don't believe there's a set screw or anything like that on them, but I could be wrong. Might need a little thwacking with a rubber mallet. If you're worried about the rotor, drape a towel over it to protect it and start off with some gentle-ish taps on the backside of the rotor. Might just need a few taps to get it loose.
Old Jan 4, 2015 | 08:09 AM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Once you have the calipers off , remove the set screws and you will need to use a hammer to break it loose . Use anti-seize and clean all the corrosion off before rebuild . It will be much easier next time .
Old Jan 4, 2015 | 08:21 AM
ArtB's Avatar
ArtB is a jewel in the roughArtB is a jewel in the roughArtB is a jewel in the rough
As stated, there is no physical retention for the rotors once you remove the retaining screws. Corrosion and grime tends to fuse them to the hub, so use a dead-blow hammer if you plan to reuse the rotors. If you aren't familiar with a dead-blow hammer, it looks like a rubber mallet but has lead shot inside of it and helps with things of this nature without damaging the surface of the media you are working with. A hammer can dent the rotor surface or if you hit it hard enough, it can crack the rotor.
Old Jan 4, 2015 | 08:43 AM
Thanks for confirming everything I needed to remove is already done. I don't have a lot of tools here in Plano so I'll go out this morning and pickup a new dead-blow hammer and give it a try.
Old Jan 4, 2015 | 08:53 AM
ArtB's Avatar
If you have a Harbor Freight close by, they have them pretty cheap. You can also try to squirt some "Deep Creep" or WD40 from behind the rotor to seep in. If you hit the outer rim of the rotor around the edge, the leverage will help pry it off. It may only take a small amount of force. But be prepared to give it a wallup if not! I always put a lug nut on one of the studs so the rotor doesn't fly off. Let's just say I may have knowledge of someone (maybe me, maybe not) doing this very procedure on a Lotus Esprit and ending up with several stitches from the projective rotor!
Old Jan 5, 2015 | 08:31 AM
Dead-blow hammer wasn't enough with cramped space. Used small 3lb hammer and plywood to protect rotor got them off.
Old Jan 5, 2015 | 09:29 PM
ArtB's Avatar
Yes sir! I have broken dead blow hammers before pulling discs, but they are cheap and never want to beat on my rotors on either car with a hammer, no matter how much padding I have. Glad you managed to separate them!
Jul 29, 2019 11:13 AM
Sep 1, 2015 03:16 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
Jeff1smith
Aug 19, 2015 09:41 PM
