clutch life assessment on vantage S v8
Old Feb 18, 2015 | 10:21 AM
jjrho's Avatar
jjrho is infamous around these parts
hi, looking at a used vantage S, v8....has 29K miles, used for daily/commute;.... how do I figure out what the clutch life is on these ?
also, if I have to do a clutch job afterward..... what am I looking at $??
is there a indicator like the lambos??
james
so.calif
Old Feb 18, 2015 | 11:58 AM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
If it's a sportshift, dealership's AMDS can provide a read out on the clutch. The cost of the OE clutch job is around 5-6K
Old Feb 19, 2015 | 12:38 AM
jjrho's Avatar
clutch life indicator
i talked to a serv. advisor at bet hills aston martin and he said the indicator readings are VERY inaccurate…he wouldn't trust the reading … there is no window or other way to check it other than to open up the car….
on the vantage S…7 speed auto clutch…is it better to manually up/down shift using the paddle shifter vs. using it as a full auto ? (i.e. to extend the clutch life that is…. ? )
jR
Old Feb 19, 2015 | 02:08 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Not true
In AMDS you can see a wear index and detail of the kiss & bite points
All of which will give a good indication of the state of the clutch
An ANY version of ASM it is best to avoid D (full auto), much better to use the paddles with a slight lift on up changes.
Old Feb 19, 2015 | 02:01 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
The dealer guide for sportshift recommends manually shifting... I let my car rest for about 30 seconds before driving after starting for the clutch 'kiss' which measures clearance.... I suspect premature wear might be not allowing time for this adjustment.
Old Feb 19, 2015 | 03:08 PM
Bleen's Avatar
Bleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of light
A SS car with 30k miles of being a DD... I'd bet the clutch is about gone. Would not buy that car without either a new clutch or money/discount for one.
Old Feb 19, 2015 | 03:36 PM
J doubleU's Avatar
Any dealer can get the values on AMDS but, wear indication can only be accurate if you have the values recorded when the clutch was brand new. Not every car is the same so good or bad can still be a estimate. Its still a wear item that depends on before and after readings. Dealer dosent want to say it's all good, when they aren't 100% sure. Plus it depends on how the TCM views the measurement.
Hybrid
Jun 28, 2024 06:05 AM
oo7
Sep 10, 2015 08:08 AM
GSP
Sep 9, 2015 05:31 AM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
