Battery Conditioner Storage Location
Old Feb 18, 2015 | 12:54 PM
hrdlyhuman's Avatar
hrdlyhuman is infamous around these parts
I have what is probably a dumb question...I bought my car used (2008 V8V Roadster) just before winter, and looking at the build sheet for the car, the battery conditioner was included. However, I cannot find the thing. I know it is certainly possible the previous owner lost it, but, I can't even find a place where it looks like it would make sense for it to go. All the manual specifies is that it is in the trunk. The compartment below the 12V socket is completely full with the compressor / flat tire kit, I don't see how you could even fit anything else in there. And there are no other obvious compartments in the trunk.
Can anyone point me in the right direction? Again, this is a roadster, I assume that might matter.
Old Feb 18, 2015 | 02:27 PM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
It's probably not there, it comes in a box about the same size as a shoe box but half the "depth" and I dont think there are any compartments to hide it. If it does I would like to know as well so I can hide mine
Old Feb 18, 2015 | 02:56 PM
hrdlyhuman's Avatar
Thanks, appreciate the info. It does seem odd to me that AM wouldn't have designed a place to put it, I guess it's just not meant to be stored in the car.
Old Feb 18, 2015 | 04:39 PM
midwestamv8's Avatar
midwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud of
There really isn't a "spot" for it. I keep mine (the CTEK) in it's bag just loose in the trunk.
As it seems you'll need one, don't get the OEM one. It's just CTEK internals. Grab
this charger this charger
and
this plug this plug
. To emulate the slow charge of the OEM unit, charge your aston on the "motorcycle" mode for the CTEK 3300.
Old Feb 18, 2015 | 05:57 PM
hrdlyhuman's Avatar
Yeah, I saw that charger mentioned on another thread when I was searching for the location. Does anyone know the difference between the 3300, 4.3, and 7002?
Old Feb 20, 2015 | 09:04 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
As it seems you'll need one, don't get the OEM one. It's just CTEK internals. Grab this charger and this plug. To emulate the slow charge of the OEM unit, charge your aston on the "motorcycle" mode for the CTEK 3300.
For just a few more $$$ you can get this one, as I did. It has a couple more modes, such as "recondition".
Amazon.com: CTEK (56-864) MUS 4.3 12-VoltBattery Charger: Automotive Amazon.com: CTEK (56-864) MUS 4.3 12-VoltBattery Charger: Automotive
Old Feb 20, 2015 | 09:12 AM
yankee04's Avatar
yankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond repute
Originally Posted by dicktahoe
For just a few more $$$ you can get this one, as I did. It has a couple more modes, such as "recondition". Amazon.com: CTEK (56-864) MUS 4.3 12-VoltBattery Charger: Automotive
My car was also missing the charger even though it was pictured in the dealer for-sale photos. I bought a Genius 3500 which I can use a variety of toys.
Old Feb 20, 2015 | 01:20 PM
Bleen's Avatar
Bleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of lightBleen is a glorious beacon of light
Motorcycle mode? I use car mode... what's the difference/why use motorcycle mode?
Old Feb 20, 2015 | 03:07 PM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
One Half the car Rate
CTEK technician advised me to purchase as above and to use the motorcycle icon for maintenance. Probably good advice for any vehicle in storage.
Old Feb 20, 2015 | 04:11 PM
Motorcycle mode is half the charge rate of car mode, and IIRC is the rate at which the OEM unit charges the battery (the OEM doesn't have two rates, just "normal" which is equivalent to the motorcycle rate on the 3300). I doubt you'll do anything harm on the car mode, but just to be safe I try to emulate the OEM recommended rate.
Old Feb 20, 2015 | 05:37 PM
Bleen's Avatar
Whoops, been using car mode for a while now...
Old Feb 21, 2015 | 08:28 AM
dicktahoe's Avatar
[QUOTE=flinder;4295444]CTEK technician advised me to purchase as above and to use the motorcycle icon for maintenance. Probably good advice for any vehicle in storage.[/QUOTE
Well that clears up a question. My OEM Aston Charger failed so I returned it to CTEK, with a note to fix it and I would pay them. They returned it un-fixed and told me to take it to my dealer. I wrote CTEK in Sweden and told them I thought that was poor customer service. So they sent me a new charger to replace the OEM unit. I was surprised it was a motorcycle charger Model US0.8. I've been using it for the past year and it works just fine to keep my Battery maintained.
Jul 29, 2019 11:13 AM
adnanm3
Oct 10, 2017 08:59 AM
DSCOFF
Aug 23, 2015 01:22 PM
