Changing exterior door handles....
Old Apr 23, 2015 | 07:25 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Ok, I've got the interior stuff off, but I can't remove the housing that holds the exterior handles in order to remove them for exchange.
I can see the three screws that hold the door handle housing but one screw is in a position that requires me to remove the door latch to get access to the screw for removal. What am I missing here?
A little help since I would love to get this done tonight.
Thanks all!
Old Apr 23, 2015 | 07:49 PM
P.S. Bought a pair of carbon fiber door handle. Would love to get them installed.
Old Apr 24, 2015 | 02:33 PM
^^No one???
Old Apr 24, 2015 | 02:59 PM
anton28's Avatar
anton28 has a spectacular aura aboutanton28 has a spectacular aura about
Wish I could help. Looking forward to the pictures
Old Apr 24, 2015 | 03:37 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Early Service Manual Information
I was only able to find one reference for removing the external door handle in my early copy of the service manual.
See Step 28 and Figure 10.
There apparently are other items (27 steps?) that need to be removed before access may be available; i.e. door glass, etc.
Not sure which of the three nuts is giving you headaches, as they appear to be accessible in the photograph (but we all know how that goes ).
File Type: pdf
Old Apr 24, 2015 | 04:13 PM
Thanks, the internal configuration has changed slightly. One nut is not accessible because it's behind a part that I would have to remove.
It's scheduled for the dealer. I'll let them take out the glass, since that's the only way to get to that bolt. (This presents a sensitive alignment issue. So I'm going to leave it to them).
Old Apr 25, 2015 | 02:13 AM
sanengo's Avatar
sanengo is infamous around these parts
Don't you mean $$$$$$$ good luck!
Old Apr 26, 2015 | 11:20 AM
I think I've got this figured out. My thought was that I needed to remove the window, which I don't want to do. Instead, I merely need to remove the lock set, and that should allow me access to the one screw I could not get to.
Old Apr 26, 2015 | 01:25 PM
karlfranz's Avatar
If it turns out you do need to loosen the window, I say leave it and let the dealership handle it. When my 07 V8V had the door locks go wonky (as all the ones built in Spain used to) the dealership replaced the door modules which required loosening the window.
Re-tightening to the correct torque is a very critical adjustment with little margin for error. In my case, the tech accidentally turned it one click too tight and the window exploded into literally thousands of pieces all over the shop floor. Some of them cut him in the face and although they tried their best to clean up all the shards, I kept finding little pieces of glass that were rattling in the door frame for the next 3 years.
I wound up driving a new Jag for the next week while they ordered and installed a replacement window.
Old Apr 27, 2015 | 01:53 PM
Originally Posted by karlfranz
If it turns out you do need to loosen the window, I say leave it and let the dealership handle it. [snip...]
Re-tightening to the correct torque is a very critical adjustment with little margin for error.[snip...]
I agree 100%, which is why I stopped at the point that I did. FWIW, I had the inner door panel off, but it looked like I needed to remove the windows before I could go any further. Well the car is due at the dealer this Friday for the seat heater recall, and I'll have them take care of the door handles at that time.
Cheers!
Old May 5, 2015 | 10:24 AM
Thanks for the advice here. The door handles are in. I also had them pop in the front LED markers while she was in
"Yellow Tail" is looking lovely!! I'll try to get some pictures up by these end of this week.
Cheers!
TAC
COBB Tuning
Jan 1, 2025 09:02 AM
nlakind
Nov 6, 2015 10:15 AM
RallyBird
Oct 7, 2015 01:20 PM
Michael_s
Sep 11, 2015 08:03 PM
00aston
Aug 27, 2015 12:01 AM
