Db9 atf?
Old Jun 3, 2015 | 02:37 PM
MRY's Avatar
MRY
MRY is infamous around these parts
Db9 atf?
Hello all,
What brand do you use in a DB9 with the ZF6HP-26 automatic gearbox?
Pentosin ATF1
Swepco ATF 10wt
Swepco ATF 20wt
Shell
Aston oem ATF
Or?
I do not believe in sealed transmissions, and believe in servicing the gearbox.
Thanks!!
Old Jun 3, 2015 | 04:51 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Forum Search is your friend...
Check out the following thread:
https://www.6speedonline.com/forums/...fluid-db9.html
Old Jun 3, 2015 | 05:42 PM
MRY's Avatar
MRY
Db9 atf?
Originally Posted by DonL
Thanks Don!
Old Jun 4, 2015 | 01:00 PM
XJRS Owner's Avatar
MRY...
Trying to PM you, but can't because your in box is full. Can you clear some space?
Old Jun 4, 2015 | 02:13 PM
MRY's Avatar
MRY
Db9 atf?
Originally Posted by XJRS Owner
MRY...
PM box now cleared!
Old Dec 23, 2015 | 09:53 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
What is the fluid capacity of the automatic?
Old Jan 24, 2016 | 03:23 PM
Organeer's Avatar
Organeer is infamous around these parts
Does nobody ever read their handbook? It usually contains the best advice and information.
Old Jan 24, 2016 | 09:06 PM
randyb's Avatar
Use ZF Lifeguard 6, to drain the most out, disconnect the return cooler line at -the radiator also. I got out 8 quarts + or - a few ounces.
KOCF
Jul 18, 2019 03:09 AM
airbusdrvr
Dec 27, 2015 07:43 PM
Ekaplan1020
Oct 2, 2015 07:39 AM
Collinsjd
Sep 29, 2015 09:38 AM
Brooklyn boosting
Sep 16, 2015 10:05 AM
