headlight assembly misadjusted?
Old Jul 22, 2015 | 01:06 AM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
Ive owned the car for 2 years and just noticed that the headlight seems to be out of position vs the fender opening. its sitting too low, like someone sat on the headlight and it moved 1/2" into the fender so its not flush now. anyone know how to remove and re-install the headlight???
Old Jul 22, 2015 | 10:07 AM
XWCGT's Avatar
help!!!!
Old Jul 22, 2015 | 11:08 AM
J doubleU's Avatar
Remove the wheel and liner to access the engine airbox for removal. 3 bolts hold it in upward and have aluminum adjustment nuts to set position. You will figure it out with everything out of the way. Although if someone did sit on it, additional damage may have incurred. Bent or broken brackets, hopefully not a broken headlamp.
Old Sep 23, 2015 | 07:20 PM
XWCGT's Avatar
Forgot I posted this awhile ago
Ok
Just looks like I'm missing something that threads through the gray gear like spacer (that rotates too) and pushes the headlight up into the fender opening
Old Sep 25, 2015 | 11:49 AM
XWCGT's Avatar
can someone please give me some advice here.... i have a piled up napkin spacing the headlight in position now.... eventually it will fall out and the light will have no frontal connnection. how or what is usually there. does Aston Bits have the part too if it is a thing i can buy?
Old Oct 8, 2015 | 02:20 PM
XWCGT's Avatar
Little help... are you guys telling me noone knows how the headlight is installed and what that forward piece looks like or where to get one? i have a crumpled up napkin holding up my headlight on my Aston martin! this is not right!!
Old Oct 9, 2015 | 08:36 AM
J doubleU's Avatar
Aston # 8G43-13037-AA headlamp adjuster.
Old Dec 2, 2015 | 11:05 PM
XWCGT's Avatar
how do you put it in.... doesn't look like there is a lot of room to reach anything. just the fender liner removed upfront and that gives enough access?
Old Dec 3, 2015 | 08:35 PM
karlfranz's Avatar
You need to remove the airbox.
xbox_fan
Sep 13, 2015 01:25 AM
su_maverick
Sep 8, 2015 11:12 AM
midtownlandman
Sep 3, 2015 01:17 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
