Vantage V8 fuel pump issue. Fuse vs Fuel pump driver module
Old Nov 17, 2023 | 02:04 AM
quadcamboy's Avatar
quadcamboy is infamous around these parts
Originally Posted by rmrmd1956
Fuel pump module is not sending its monitoring signal check to the PCM. Read the attached OBD2 info, check fuse F9 in trunk, see attached circuit diagram. FPDM is hard to get to, see picture.
"Hard to get at"? Too bloody right! Found two broken earths which restored the DIM when reconnected, P1233 fuel system still offline though, measuring voltages at the FPDM as per your attachment, this morning.
Old Nov 21, 2023 | 11:47 PM
quadcamboy's Avatar
Hi all, earth's repaired and still chasing P1233 fuel system disabled. Following the Aston "technical bulletin/fault finding flow chart thing posted by rmrmd1956 above. Need to check wiring between "PCM" and fuel pump driver module.
Two questions: 1 Presumably that's the power train control module? Or engine management ECU?
2 Aston Martin Technical Hub download (cheers Irish) shows engine management roughly between front suspension tower and brake servo. It isn't, so where do I find it?
Cheers Quad
Old Nov 22, 2023 | 02:43 AM
quadcamboy's Avatar
Found this this morning, stand easy
louisifis
Nov 2, 2020 01:16 PM
pwdrhound
Sep 13, 2016 10:44 AM
BG305
Cayenne 955/957
Feb 11, 2015 07:14 AM
marsfire
Aug 8, 2011 05:22 PM
SkierMan
911
Sep 12, 2006 07:41 PM
