Front Brake Rotors
Old Nov 14, 2021 | 10:21 PM
convexproblem's Avatar
convexproblem is infamous around these parts
Originally Posted by Kalepsis
I am also researching rotors, in case I can't find a shop that can resurface the ones on the car when I swap pads. I'd love to use Wilwood rotors but I'm not in that price range (nevermind carbon ceramics). I plan to get the Brembos for my '09 Vantage. Here are the part numbers:
Front: 09.8780.21 (355mm for 06-12 Vantage and DB9)
Rear: 09.8781.21 (330mm for 06-12 Vantage and DB9)
Bumping this thread while doing some aftermarket part hunting, thanks Kalepsis for the part numbers. Thought I would save and share the rotor measurements off Brembo's website if anyone wants to bargain hunt to avoid the Aston tax.
Spec/Front (mm)/Rear (mm)
Hat ID: 164/160
Hat OD (stock cast iron): 176/172
Rotor OD: 355/330
Rotor ID: 226/222
Thickness: 32/28
Hat face thickness: 6.5/6.5
Total height (stock cast iron): 52.5/46.5
Height from far rotor face to hub: 46/40
Height from near rotor face to hub: 14/12
Hat offset (to center of rotor): 30/26
Rotor vent thickness: 12/8
Min thickness: 30/26 (aka 2mm wear)
Center bore: 71/71
Mass: 12.3kg front/9.6kg rear
Note that the Wilwood kit has 9.0"=228.6mm ID on the rotor which is greater than the 226 stock, and uses a 8.25" rotor bolt circle diameter with what appears to be "fixed" style mounts instead of "dynamic".
Brewerg
Aug 18, 2016 08:12 PM
karlfranz
Jan 10, 2015 11:22 AM
ArtB
Oct 2, 2013 08:53 AM
007 Vantage
Jan 10, 2013 09:41 AM
