Front Brake Rotors
Old Nov 25, 2015 | 11:20 AM
Madmikeybee's Avatar
Madmikeybee is infamous around these parts
Front Brake Rotors
Hello,
Does anyone have the answer to this?
Will the front brake rotors from a 2015 Aston Martin V8 Vantage fit on a 2007 Aston Martin V8 Vantage? I want to keep my calipers.
Many thanks! Cheers!
Old Nov 25, 2015 | 11:22 AM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
No, they are different in size. 2015 front rotors are bigger.
Old Nov 25, 2015 | 12:52 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
If you want better brakes, just get the 2-piece brembo rotors, they will significantly improve brake performance as well as ride comfort and steering input. The suspension will respond better to bumps in the road as well
Old Jun 13, 2016 | 06:28 AM
SinisterSF's Avatar
5 Year Member
SinisterSF is infamous around these parts
Do you know if Brembo makes a rotor for an 08 DB9? Part numbers?
Old Jun 13, 2016 | 07:03 AM
telum01's Avatar
4-piston brakes are the same on both DB9 and V8 Vantage.
Wilwood makes 2-piece rotors as well.
Old Jun 13, 2016 | 07:08 AM
SinisterSF's Avatar
5 Year Member
I know vantage and db9 interchange. I've also heard nissan 370s have a compatible rotor, anyone else heard this?
Old Jun 13, 2016 | 02:43 PM
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
Here's my old post with part numbers and review of brembo brakes on a 2007 Vantage.
https://www.6speedonline.com/forums/...de-review.html
I've since changed to portfield pads for street use as they are less noisy (actually porterfields exhibit zero squealing) but there is still some clicking noises from the floating rotor/hat hardware.
Old Jun 13, 2016 | 03:12 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Google redpants Aston Martin. And just order the right stuff from the guy that knows his s@&$$ t
He will advise why you need
Old Jun 13, 2016 | 03:33 PM
telum01's Avatar
I believe the diameter is the same for certain ones, but can't account for other specs. Just measured the OEM and Wilwood rotors:
OEM Brembo front rotor is 1-3/16" (1.1875") thick.
Wilwood front 2-piece rotor is the same.
The only spec I've seen on the OEM 370Z front rotor is that it's 1.26" thick, but I can't verify that. Don't know about anything other specs for it, either.
Lol! I've heard good things
Old Jun 13, 2016 | 04:16 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Telum1,
Do you have a part nbr for the wilwood's?
Old Jul 21, 2018 | 07:27 PM
Stealthssfc's Avatar
Stealthssfc is infamous around these parts
V8 Vantage S rotors
I was recently in need new front rotors for my V8 Vantage S and wasn’t willing to pay the stealer $3400 for a new front set. After a couple days of digging, emails and phone calls, I was able to source a new set for just under $1000. Racing brake had a set that worked out perfectly. Warren was the gentleman there that helped me out and was very helpful. They were actually made for the Nissan GTR but apparently the Brembos they use are the same size, 380x34mm and have the same rotor hat PCD. I just installed them on my factory hats with the new hardware that was included and they work perfectly. They are supposedly a pound lighter than the brembos too. For those who are interested or will need new ones in the future here is a link to them. Less than a third of the price aston charges!
https://www.racingbrake.com/OE-Ring-...503-01-311.htm
Old Jul 21, 2018 | 07:35 PM
V8 Vantage S rotors
Old Mar 26, 2020 | 11:34 AM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
Reluctant to weigh in on this but....
47000 miles on carbon ceramic system (2012 V12 Vantage)
tracked only once
at recent inspection (where I expected to have to spring for new pads) adviser said pads were about 50% worn and probably good for another 40000 miles
rotors look new
no brake dust at all...stops on a dime
owner's manual cautions about aggressive cleaners' effect on the rotors
Thanks,
JH
Old Mar 28, 2020 | 02:27 PM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
I am also researching rotors, in case I can't find a shop that can resurface the ones on the car when I swap pads. I'd love to use Wilwood rotors but I'm not in that price range (nevermind carbon ceramics). I plan to get the Brembos for my '09 Vantage. Here are the part numbers:
Front: 09.8780.21 (355mm for 06-12 Vantage and DB9)
Rear: 09.8781.21 (330mm for 06-12 Vantage and DB9)
A set from onlinecarparts.co.uk costs 365 GBP ($455).
Old Mar 28, 2020 | 02:41 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
See: https://aston1936.com/2019/11/06/bra...on-martin-db9/
Vantage and DB9 use the same rotors until Vantage S.
