Aston's 5.2L Twin-Turbo V12
Old Mar 3, 2016 | 07:16 AM
telum01's Avatar
Some good info and pics in this one
http://jalopnik.com/this-is-the-all-...nyb-1762277760
Old Mar 3, 2016 | 07:31 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Inside The Aston Martin DB11's 5.2 Turbo V12 video
Although a little hard to hear, lots of information presented.
Old Mar 3, 2016 | 08:01 AM
telum01's Avatar
Awesome video, thanks!
Fantastic packaging on the engine setup with the twin turbo system. And keeping it within 5-kg of the outgoing despite the extra hardware is really impressive.
516 lb-ft from ~1500 RPM, peak power of 600 HP at 6500 RPM, and 7000 RPM redline. Not too shabby. And I like the "easily 600 HP" comment... I'm willing to bet the Vanquish is going to get an uprated version of this engine.
Really interesting point about the oil system. There was a discussion on PH a long time ago about how the V8V's dry sump robs about 20 HP and Aston's engineers couldn't figure out how to optimize it (or something along those lines). I wonder how much power they'd have lost on the 5.2L V12TT with a dry sump?
Old Mar 3, 2016 | 08:27 AM
norbert6speed's Avatar
norbert6speed is just really nicenorbert6speed is just really nicenorbert6speed is just really nicenorbert6speed is just really nice
The torque curve looks great, nice to see the engine still likes to rev
Old Mar 3, 2016 | 12:24 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Interesting justification for the forced induction: it's the customers that want it. So there is no pressure to turbocharge for efficiency/governmentally legislated reasons?
Hooray for cylinder deactivation. Much better than 'stop/start' as fitted to some cars (for example, BMW, Jag) IMO.
Admittedly any clips of the sound that are currently on the internet are very limited, but it sure sounds muffled to me when compared to the outgoing V12.
Old Mar 3, 2016 | 02:22 PM
deckman's Avatar
I wonder how easy it will be for tuners to up the ante on these with bigger turbos, injectors, etc. People will turn a $200k car into a $300k car that will be worth less than a stock car at resale. You watch.
Old Mar 3, 2016 | 02:36 PM
XJRS Owner's Avatar
Looks like the coils are going to be accessible without tearing the whole top of the motor off? That would be good.
Old Mar 4, 2016 | 08:17 AM
rscultho's Avatar
rscultho is infamous around these parts
I have owned two turbo charged cars...1993 Mit VR4...replaced both turbos after 4 to 5 years. Hopefully turbocharger technology, quality, reliability has improved alot since then.
The biggest issue with turbos used to be how they cook the engine oil. I suppose synthetic oil handles that issue much better, but does the turbo heat reduce the life of the oil/decrease oil change interval time?
Old Mar 4, 2016 | 12:21 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
This graph must be a representation, I have never seen a turbo HP graph that perfect.
Old Mar 4, 2016 | 12:28 PM
telum01's Avatar
Yes, it's a marketing graph - shows the general output of the engine. It isn't an actual dyno plot.
Old Mar 4, 2016 | 12:31 PM
DonL's Avatar
Marketing Department graph vs: Engineering Department graph
Old Mar 4, 2016 | 01:53 PM
randyb's Avatar
Figured it was, but you never know. Someone might have invented the perfect turbo.
Old Mar 4, 2016 | 08:06 PM
ncamv8's Avatar
ncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to all
If Aston took a page from BMW, they use the electronic wastegate to manage the torque curve. I have 135 Dinan and did before and after dyno runs, mostly what Dinan did was to hold the wastegate closed a little longer and let the boost build more.
So essentially they have the computer open the wastegate to hold the power where they want it.
Old Mar 4, 2016 | 08:16 PM
telum01's Avatar
The DB11's turbos have electronic wastegates
Old Mar 4, 2016 | 09:28 PM
ncamv8's Avatar
That is what I heard in the the video that DonL posted.
it's mentioned at about 3:14.
