2006 Vantage VelocityAP X pipe install
Old Mar 26, 2016 | 10:00 PM
ArtB's Avatar
ArtB is a jewel in the roughArtB is a jewel in the roughArtB is a jewel in the rough
I got my X pipe for the 4.3L Vantage yesterday from Stuart! Very good quality part, shipping was fast and the install went almost without any problems... I found that having the entire exhaust system from the muffler up to the cats loosened, made it go much more smoothly! Plenty of Deep Creep(WD-40) or the like worked wonders and the whole job took me about 2.5 hours with a lunch break! Unfortunately it rained all day so I didnt get any video of the startup nor did I get a chance to drive the car but I will add that as soon as the weather allows. I do have some video of a flybye from before the X Pipe so I am interested to see (hear) the difference!
Package arrived from Velocity!
Old midpipe section
Don't forget to remove this from the old midpipe assembly! You will need it
New X Pipe
All bolted in and tightened down.... Wiaring for some dry roads
Old Mar 31, 2016 | 11:09 PM
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
Thanks for sharing.
I'm considering this along with the 200 cell cats and tune for my 2007 Vantage.
Any impressions on how the xpipe sounds and feels?
Old Apr 1, 2016 | 07:17 AM
ArtB's Avatar
Originally Posted by spyder997s
Thanks for sharing.
I don't know that I can feel a butt dyno difference, not that I had expected any power gain, but the smoothing out of the exhaust sound is noticable. I have gotten busy on a project with my Esprit so I forgot to take video with the xpipe sound. I have before video so I will do a short video this weekend to post some clips. I think the sound is mellowed some but the tone is a bit more exotic in my opinion, it sounds great and I retained the fuse 22 so the car is still quiet at idle! I will post some video this weekend so you can compare. The part is well worth the price of admission and is factory quality!
Art
Old Apr 1, 2016 | 08:27 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Looks great! X/pipe will lower the overall volume slightly but it gives the exhaust note a much smoother exotic sound due to the balancing of the exhaust pulses. This also filters out any harsh harmonics in the exhaust note. You desperately need to upgrade the stock cats to get the full power & sound benefits
Old Apr 1, 2016 | 09:48 AM
spyder997s's Avatar
I'm looking for more engine and exhaust roar that I can hear from inside the cabin, if that makes sense.
I'll consider the xpipe after 200 cell cats and tune 1st, since it may lower sound, and we still have the option of adding fuse 22 back in (mine is pulled out all the time now with my stock configuration).
It seems like the 200 cell cats plus tune are the biggest bang for the buck with the 4.3 engines!
Old Apr 1, 2016 | 11:19 AM
ArtB's Avatar
The "stock cats" are an illusion! There is nothing inside them! They are hollow now!
Old Apr 2, 2016 | 11:58 AM
You clever guy you
Old Apr 6, 2016 | 07:01 AM
ArtB's Avatar
The side street video is after. The highway vid is before the pipe. No other changes made between the two videos.
Old Apr 6, 2016 | 07:47 AM
Sounds great, X-pipes definitely help refine the exhaust not and give them that more European exotic note. I think it's a must no matter which brand you choose
Old Apr 6, 2016 | 10:12 AM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Maybe it's me but I am having difficulty identifying a discernible difference in sound.
Old Apr 6, 2016 | 11:17 AM
ArtB's Avatar
There is a subtle difference, the Xpipe has reduced the rasp at higher RPM but overall not much change. Either way, it sounds great to me and the smoother upper RPM note is much more exotic.
Old Apr 6, 2016 | 10:42 PM
Dyno footage illustrates how much smoother the X-pipe roars at high rpms. A much more sweet exotic sounding note than the brash V8 with high flow cats.
If you plan on going HFC, X-pipe is almost mandatory.
Old Apr 7, 2016 | 12:09 PM
telum01's Avatar
Was it necessary to put a competing vendor's advertisement in a thread for another vendor's product?
Old Apr 7, 2016 | 04:00 PM
ArtB's Avatar
FABSPEED MOTORSPORT | Aston Martin V8 Vantage Secondary Catbypass X-Pipe - YouTube
I believe the X pipe for the 4.7 is much different in how the layout is between the 4.3 and 4.7L engines. I will try to get some highway speed video soon to really compare the revs, gears and noise generated on the highway"before" x pipe vids. It is difficult to compare sound with 2nd gear lower revs drive by than higher speed highway pull at 50-60 mph!
yvesvidal
Apr 24, 2018 09:21 PM
