Removal of Side Repeaters
Old May 6, 2016 | 08:51 AM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Hi All-
I ordered a pair of smoked side repeaters. While I await their arrival, I'm wondering how to remove them. I hope this isn't another long process of removing inner fenders simply to change a bulb.
As usual, all input will be greatly appreciated.
TAC
Old May 6, 2016 | 08:54 AM
telum01's Avatar
Yep, you have to pull back the fender liners. But they're pretty easy to get to, not much in the way. You can see them in my door strut video on YouTube. I show where they are because I snapped one clean off while changing my door struts hahahaha
Old May 6, 2016 | 08:59 AM
Darn, darn, darn!! I was hoping I wouldn't have to do that. I don't have a lift, nor do I have a jack and stands.
Actually, it was your car that finally "drove" me over the "edge". I got light bulb envy when I saw your smoked repeaters.
Old May 6, 2016 | 09:02 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Originally Posted by terminal_ac
Hi All-
TAC
Not to hijack the thread, but where did you get them?
Old May 6, 2016 | 09:14 AM
ebay. search terms: "side repeaters aston martin"
Old May 6, 2016 | 09:26 AM
randyb's Avatar
Thanks!
Old May 6, 2016 | 09:27 AM
karlfranz's Avatar
You don't need a lift to change them. Just turn the wheel fully in the direction of the side you want to gain access to so there is a bigger gap at the rear of the wheel well. Removing some of the bolts along the trailing edge of the wheel well liner should give you enough access to move it out of the way and stick your hand in. A quarter turn removes the bulb holder from the back of the lens. The lens comes off from the outside with one quarter turn as well.
Old May 6, 2016 | 10:17 AM
telum01's Avatar
Ahh sorry sorry, sometimes I'm a bad influence
What KF said! There's lots of space in there so as long as you can get your hand between the liner and the fender itself, you shouldn't have a problem.
Old May 6, 2016 | 10:20 AM
Yup, this was going to be my first technique!
Old May 6, 2016 | 12:46 PM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Ah man I still have my jack and jack stands back at my parent's place in NJ
Old May 6, 2016 | 01:28 PM
dsvantage's Avatar
dsvantage is infamous around these parts
Does anyone have a source for the clear OEM ones? I'd actually like to remove my smoked units and replace them with stock.
Old May 6, 2016 | 02:04 PM
How ironic, but astonmartinbits has them.
Old May 6, 2016 | 03:44 PM
karlfranz's Avatar
You can also get them through any Ford parts dealer. They are the same ones used on the Ford Transit.
Old May 6, 2016 | 10:00 PM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
That's good to know about the ones from Ford. I ordered some on eBay a while back but they did not even get close to fitting. I returned them and never received a refund.
Old May 6, 2016 | 10:03 PM
Might I ask where you ordered them from?
