Help
Old Jul 24, 2016 | 06:25 AM
larryg's Avatar
larryg is infamous around these parts
Help
Took my 2014 V8V for a ride earlier today.
The display areas in the tach and speedo gauges are completely without any info i.e. no odometer, TPMS, etc.
Did I turn it off or is there a problem?
Yellow triangle stays on as well
Car runs fine
Old Jul 24, 2016 | 08:52 AM
handyman2009's Avatar
Veteran: Canadian Forces
Larry, Push the button at the end of the left arm on the steering wheel to go to different settings as there is one that shows nothing. As for the yellow triangle, as you cycle the different view you will see what the triangle is for and you can "Read" it and accept it by pressing the "Read" button in the center stack.
Old Jul 24, 2016 | 09:22 AM
larryg's Avatar
The end of the left stalk seems to do nothing.
How do I specifically define the meaning of the yellow triangle?
Much appreciate the response.
Car has only 500 miles
Always in climate controlled environment
Never wet
Old Jul 24, 2016 | 09:37 AM
Larry, I just tried it in my 2009 Vantage... You have to close all doors, trunk, hood and start the car and then when you push on the button at the end of the left arm it will cycle different output (ie: gas left in the tank, MPG, average speed, current speed, blank
Old Jul 24, 2016 | 09:49 AM
larryg's Avatar
Did as you instructed
The yellow triangle did go out but the button at the end of the stalk is still inoperable.
Is there a fuse
I have a feeling that I am missing something very simple
Much thanks
Old Jul 24, 2016 | 09:55 AM
The triangle was probably for an open door... I would look in the manual and see if there is a fuse, never had that problem before. if you take the car out for a drive, every thing else work ie: needle on the speedo and tach ?? I will look in the manual and see if I can find something
Old Jul 24, 2016 | 10:00 AM
larryg's Avatar
Gauges work fine
Thanks much
Old Jul 24, 2016 | 10:15 AM
the only fuse that I see could be this one but if blown more stuff wouldn't be working:
Cabin Fuses
Fuse Rating Function
F46 5A
Driver Information / Master lamp switch /
Glove box relay / Master lock switch /
Battery disconnect switch / Trunk lid release
/ Engine bay fusebox / Bluetooth / CCM
Switcher / Battery disconnect module /
Convertible roof module (Roadster) /
Occupant classification system module.
Old Jul 24, 2016 | 11:54 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Check the dimmer switch near the headlight control? Hs it been dialed down all the way?
Old Jul 24, 2016 | 11:57 AM
Even dimmed all the way down it will still light up as I just confirm with my car
Old Jul 24, 2016 | 12:40 PM
Timodc's Avatar
5 Year Member
Timodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to behold
Is it a roadster?
Old Jul 24, 2016 | 02:29 PM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
Originally Posted by Timodc
Is it a roadster?
HehHehHeh...
He's referring to the legendary Convertible Roof Module. My saga with that spawn of Satan continues...
Old Jul 24, 2016 | 03:11 PM
Timodc's Avatar
5 Year Member
Originally Posted by zuman
HehHehHeh...
Precisely... First sign of CRM failure/CAN network down is instrument display issues.
Old Jul 24, 2016 | 04:12 PM
larryg's Avatar
Is a coupe
Very frustrating
I will try the dimmer adjustment
Old Jul 24, 2016 | 04:18 PM
larryg's Avatar
Dimmer switch was of no help
Everything seems to work but the gauge displays
Very frustrating
