CRM failed
Old Aug 26, 2016 | 10:07 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
CRM failed
My roof is open, how do I close it?
Old Aug 26, 2016 | 11:00 PM
randyb's Avatar
Where the heck is it?
I took off my driver side wheel liner and could not see it.
Old Aug 27, 2016 | 08:35 AM
J doubleU's Avatar
It's integrated into the body via a rectangle plate with 4 torx #30 fixings.
Old Aug 27, 2016 | 12:11 PM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
You did go to the left side/rear wheel, right?
As mentioned, you remove the wheel well liner, then there's a rectangular panel at about the 11 o'clock position as you look at the side of the car. The CRM is actually attached to the back of the panel (the replacement part includes a new panel). Be careful with the fuel overflow drain tube, which is clipped to the back of the liner.
Be aware that removing the CRM won't allow you to close the roof - you need a new unit for that. Simply removing the CRM WILL make all the other associated gremlins go away, however.
I assume that you've tried the roof after letting the car sit and cool down, right? Many times the problem is intermittent, and after sitting the car for a while the roof will work again. Then you can remove the CRM with the roof closed and use it until you get a new unit.
In most cases you'll have to take your car to the dealer to get it flashed after a new CRM install.
Old Aug 28, 2016 | 10:16 PM
23546ghhga99's Avatar
23546ghhga99 is infamous around these parts
see "Convertible Top Malfunction" in this forum.
Old Aug 29, 2016 | 01:25 PM
randyb's Avatar
I had accessed the plate, but the part nbr was way different then the one I ordered, just wanted to make sure I had the area. I confirmed with AM dealer that it was the correct part, apparently some where along the way the part number changed and I mean the whole part number, not just the last letter.
Anyway, thanks for the help!!
Old Aug 29, 2016 | 03:00 PM
telum01's Avatar
As of June, the CRM part# was 9G43-L53085-AE. Not sure when that was implemented or if it's been replaced.
Old Aug 29, 2016 | 07:11 PM
randyb's Avatar
That is what I found out, the part nbr on mine is completely different. From what dealership told me, they changed the part nbr sometime ago. So when I took took the CRM out and saw that part nbr, made me think I pulled the wrong part, hence my question.
Old Aug 29, 2016 | 07:17 PM
Newest 9G43-L53085-AE.
That part number was correct for my 2009 DB9 (Volante).
The new CRM part did NOT need to be flashed.
Old Jan 31, 2017 | 02:34 PM
randyb's Avatar
My (NEW) CRM is starting to act up now, 3 times I have gotten the 'Roof Movement Pause' error message.
Has anybody else gotten this msg?
Old Feb 1, 2017 | 07:43 AM
Timodc's Avatar
5 Year Member
Timodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to behold
Not all roof concerns are caused by the CRM... you may have other issues with wiring, hydraulics, latches, or sensors.
Old Feb 1, 2017 | 08:41 AM
MikeD's Avatar
MikeD is infamous around these parts
I experienced that once or twice after replacing my CRM. I think my windows were out of sync (the rear quarters with the side windows), so I reset them and never had another problem.
My CRM was the newest part number and didn't require a visit to the dealer.
Old Mar 7, 2017 | 03:53 PM
randyb's Avatar
MikeD, how did you get your rear quarters insync?
I just replaced my drivers side rear quarter window regulator.
Old Mar 8, 2017 | 06:41 AM
MikeD's Avatar
Honestly, it was sort of trial and error until I got them to work. I think what I did was I used the roof switch to either close or open all the windows (even though they weren't all moving) until the rear quarters were both completely open or closed and then held that switch for several seconds. Then using the window switches I put the front windows in the matching position and held each of those switches for several seconds. Then I tried the roof switch and viola!
Old Mar 8, 2017 | 05:04 PM
randyb's Avatar
I saw someone post that they found a you tube video about fixing my issue by bending the the metal tang of the roof switch on the a pillar. Has anyone seen this video?
I did a search and could not find the video.
