New Aston Owner - Help, car won't start!
Old Oct 8, 2016 | 08:39 PM
JTaylorGT's Avatar
JTaylorGT has a spectacular aura aboutJTaylorGT has a spectacular aura about
I just bought my 2012 V8 Vantage S (Sportshift II w/ 21k miles) a week ago and without any warning, the car will not start tonight giving an error "Fault No Gear Change Possible". When I stepped out of the car, I slipped on the garage floor, and then discovered a huge puddle coming from underneath the car near the rear center (close to rear axle/diff) - the fluid is green/yellow (transmission fluid?). Upon further inspection, the leak appears to have started while I had the car out earlier in the day. I can see streaks along the bottom panel all the way back to the rear bumper - guess I was lucky to make it home. The car has been mostly sitting at a dealership all summer, and I've put about 300 miles on it this week (probably 150 of them today).
Looks like I'll be getting it towed Monday morning - any ideas what it could be? Really hoping I didn't just buy a car that needs a new clutch first thing!?! Not sure if this helps, but values from a PPI diagnostic scan I had done a couple of weeks ago:
Self tuned clutch closed position = 1619
Self tuned clutch closed position - kiss point delta = 447
Clutch overheat timer = 496
The shop explained my clutch looks more than 50% worn based on these numbers, but it didn't sound like end of life was in 300 more miles! Thanks in advance for any thoughts...
Old Oct 9, 2016 | 01:08 PM
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
That sucks mate, sorry to hear that. I just purchased the same make model about 3 weeks ago and would be devastated if that happened to me. Hopefully it's something inexpensive!
Old Oct 9, 2016 | 05:29 PM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
Green yellow fluid is usually antifreeze. Hope it is something simple.
Old Oct 9, 2016 | 05:45 PM
JTaylorGT's Avatar
Hmm, I did some more internet research and found someone with the same year/model car that had a similar error message and fluid coming out the rear. He said it ended up being a faulty clip on a clutch line that resulted in a hydraulic clutch fluid leak. Not sure what this fluid looks/smells like...
Does antifreeze run to the rear of the car (i.e. to the differential perhaps for transmission cooling)?
I'm calling a tow truck tomorrow but am worried b/c the car is stuck in first gear - it won't go into neutral with the transmission fault. I have no idea how we're going to push the car out of the garage?!?
Old Oct 9, 2016 | 11:39 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
damn that sucks, these cars do NOT like to sit for prolonged periods of time. hopefully it's a relatively simple fix and you'll get it squared away quickly.
Old Oct 10, 2016 | 11:01 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Sounds like it is clutch fluid, if it has green in it, sounds like the fluid has not been changed regularly. Most modern cars use brake fluid for clutches, good luck with your problem, hope it is just a clip.
Be thankful it did not happen on the road.
Old Oct 13, 2016 | 07:43 AM
JTaylorGT's Avatar
Well, that was fun. The tow truck driver was super cool and careful - he coached me through every step and came up with a solution that would not ruin my garage floors since the car was stuck in gear. It was a 2-hour process to extract the car from my garage! Basically we hosed down the floors and slid it out with a winch very carefully. Would have preferred a flatbed but that wasn't possible with the car stuck in first gear and the tight space in my driveway (I live in the city).
The shop says the Sportshift send/return lines to the rear differential failed (well, technically just the send line); Aston sells both hoses and all clamps as a kit, so they will be replacing both lines (about 3 hours of labor). Parts should arrive tomorrow so hoping to get the car back for Caffeine & Exotics this weekend here in Atlanta! Overall, a relief to know it's nothing major, just inconvenient given the mess of clutch fluid in my garage!
Old Oct 13, 2016 | 07:20 PM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
Well that is better news than I thought it would be. Your Vantage is very cool looking. I hope this is the last of your problems.
Ron
Old Oct 17, 2016 | 01:12 PM
ahcjar103's Avatar
ahcjar103 is infamous around these parts
great looking car and glad it turned out alright!
Old Oct 17, 2016 | 02:51 PM
glad you're getting it sorted, will you be making the mtn run this sunday?
Old Oct 17, 2016 | 03:29 PM
JTaylorGT's Avatar
Thanks guys, I unfortunately have a conflict Sunday but is this the drive sponsored by Motorcars for Georgia? I need to get on their email list...
Old Oct 17, 2016 | 07:01 PM
yeah it is, catch you next time.
Mauser
Bentley
38
Jun 13, 2017 03:09 PM
deilenberger
Cayenne 958
Dec 7, 2016 08:39 AM
ShortCkt101
Aug 22, 2016 05:34 PM
iPE Exhaust
Aug 11, 2016 03:27 AM
