Key FOB fell apart
Old Oct 25, 2016 | 07:43 PM
nittany's Avatar
nittany is infamous around these parts
Key FOB fell apart
Has this happened to anyone? Fell off when I was taking it out of my pocket and I lost the top portion. Didn't even drop it. It must of just popped off.
Any suggestions or do I have to buy a replacement FOB from Aston?
Old Oct 25, 2016 | 08:38 PM
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
Yes, Put in your drawer and use the real key
I never use the plastic ones. Even bought a bad glass one and transfered the guts from my Valet into it so have 2 glass ones.
Old Oct 25, 2016 | 08:43 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
I only use the plastic one when I bring it in for service!
Old Oct 25, 2016 | 09:05 PM
nittany's Avatar
Ha! I would if I wasn't Mr. Butterfingers.
I mostly do take the glass one...I take the valet key when running errands.
Old Oct 26, 2016 | 08:53 AM
The trick is to keep it in the leather case, and only remove the key from that case when you're in the car sitting down. This way, if it drops then it will fall a short distance into your lap. Butterfingers issue solved!
Old Oct 29, 2016 | 03:25 PM
nittany's Avatar
Is it possible to convert the plastic key to a glass key. I notice astonbits sells the casing for both the plastic and glass key.
If so, how hard would that be?
Old Oct 29, 2016 | 07:53 PM
Old phart's Avatar
As stated earlier, thats what I did. Took me about 20 minutes. Have a post on it either here or Pistonheads. Can't find the post but here are the pics
Parts from Valet swapped into glass key. A few dabs of glue at the corners and put it back together.
Old Oct 29, 2016 | 08:41 PM
handyman2009's Avatar
Veteran: Canadian Forces
Thanks that could be a future project
Old Oct 29, 2016 | 11:25 PM
PK_Vantage's Avatar
PK_Vantage is infamous around these parts
That's a great write up for key fob swaps.
In the mean while, my little mod will just do it for me to make the plastic valet key seem not so cheap.
Old Nov 1, 2016 | 11:16 PM
JTaylorGT's Avatar
JTaylorGT has a spectacular aura aboutJTaylorGT has a spectacular aura about
Wow, cool plastic key fob mod - where did you get the AM logo?
Old Nov 3, 2016 | 12:38 AM
PK_Vantage's Avatar
Logo was a genuine AM pin ordered from OutMotoring (a site sponsor) with its back prong cut off.
Originally I was going to do a flush/recessed mount by cutting into the top piece of the plastic fob. But quickly realized that top piece was too thin for the full thickness of the metal logo. So I end up just epoxied the pin logo instead. Not the best way to go I know....but it's better than just plain old plastic as before.
