instrument cluster removal
Old Jun 1, 2017 | 09:55 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Sick of not being able to see my digital speedo, so I am going to take it out and put on new tinting, because I cannot see spending $1,500 for a new cluster to replace the 20 cents worth of tinting.
Having said that, has anybody removed their cluster and have words of wisdom?
I looked at the service manual, but after finding it very lacking in details, I wanted to ask first before attempting this task.
Old Jun 1, 2017 | 12:32 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
This is very easy to do.
First remove the cluster cover by pulling on it. It's help by spring clips. So don't be afraid to pull it.
Second, remove the vent held in the dash cover, as well as the dash cover on the other side of the instrument cluster. Again, these pieces are held in with spring clips. Just give them a hard pull, and they will release.
Third, remove the instrument clock bezel surround. The screws are all exposed so just remove what you see.
From this point, you will see all screws for the instrument cluster.
This is very easy. One thing, you'll need a stubby phillips head screw driver to complete remove the instrument clock bezel surround.
This is not complicated. So enjoy....
Old Jun 22, 2017 | 12:07 AM
bonnie sacer's Avatar
bonnie sacer is infamous around these parts
Thank you for your sharing i really appreciated it.
Old Jun 22, 2017 | 12:44 AM
pikajew's Avatar
pikajew is infamous around these parts
I've done it before. Super easy. If you have questions, I'm happy to help.
Old Jun 22, 2017 | 10:38 PM
Timodc's Avatar
5 Year Member
Timodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to behold
Be sure never to plug in an instrument cluster from another aston... it will add the mileage of both cars and display that number in the odometer.
Old Jun 23, 2017 | 04:49 AM
CARAIBAM's Avatar
CARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of light
Can a secondhand instrument cluster be reprogrammed to the car spec using AMDS?
Old Jun 26, 2017 | 09:07 PM
it's not difficult to do that, find a tutorial video would be of some help.
Old Jun 27, 2017 | 12:03 AM
gordon9898's Avatar
gordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the roughgordon9898 is a jewel in the rough
So if you intermittently plugged in two different instrument clusters you could keep going until you rolled the odometer back to approximately zero?
Old Jun 28, 2017 | 06:40 AM
goto35's Avatar
goto35 is infamous around these partsgoto35 is infamous around these parts
Wow your steering wheel is beautiful!! From where and how much??
Old Jul 12, 2017 | 09:15 AM
randyb's Avatar
Yes, would really like some help and if anyone knows a good source for tinting I can use and also an easy way to remove tinting, that would also be welcome.
And if anyone wants to come to Tampa area and do this for me, that would be appreciated also. Hmm, I wonder if this is asking to much.
Old Jul 12, 2017 | 09:17 AM
randyb's Avatar
Thanks, this is a big help!!
Old Jun 3, 2021 | 08:05 PM
Aadil's Avatar
Aadil is infamous around these parts
WOW, those guages look incredible. I need to open mine up to fix the LED on top. I am definitely sending you a PM for help.
Old Oct 2, 2024 | 03:17 PM
ICEICEbaby's Avatar
ICEICEbaby
Does that mean the only option is to buy a new cluster from Aston Martin if the current one goes bad? Is there not a cheaper option to keep the mileage accurate?
Old Oct 3, 2024 | 07:28 AM
embdenb's Avatar
You are in St Pete, I am in Hernando county, about 30 to 40 miles north.
I believe it is more than just replacing the polarizing film. Sun and age caused the film to bond with the plastic lens. That has to be removed.
For the detailed process see.
https://bernardembden.com/am/dashrepair/index.htm
Good luck, you can contact me if you have any questions.
Old Oct 3, 2024 | 04:48 PM
Sir Rothschild's Avatar
Sir Rothschild is infamous around these partsSir Rothschild is infamous around these parts
Are those gold rings aftermarket? Where did you get them?
audiophilitis
Feb 16, 2011 06:29 PM
Astacun
Jan 24, 2010 09:26 AM
OmahaGT
Tech / How To
Oct 6, 2009 01:52 PM
villains_turbo
May 6, 2007 04:30 PM
TestnDoc
May 14, 2005 12:49 PM
