Vantage 4.7L Engine Noise
Just to clarify, I am not referring to intake or exhaust noise. I am interested in hearing your viewpoint of how noisy the top end components (cams, timing chains, whatever) of the V8 4.7L engine are at idle. Do you hear ticking or maybe a very light rattling sound or what? Hood open or closed?
The engine on my MB SL550 was quite quiet, as was the whole car. I know that it is subjective, but how quiet should the engine be after around 15K miles?
Thanks.
Thanks.
faint ticking (usually at morning cold start ups) with hood closed but no rattling noise. Currently at 11K miles.
Edit: Heard mostly from outside. Inside cabin, can't hear that tapping at all.
Hi...,09 vantage V8....inside cab...quiet
outside the car with hood closed...quiet
Hood open...normal engine...no clanging
My car has 31800 miles on original clutch-clutch-asm transmission
I hope this helps
I hope this helps
I've listened to several 4.7's and all of them have been a little tappetey on the top end, one had inconsistent clatter on the front which I believe was idler pulley time. But all had the same light clickery clackery under the valve covers.
Thanks all.
The noise I am hearing fits with your description of "inconsistent clatter" and seems to be more centralized rather than from one bank or the other. Can you provide a little more information on the idler pulley and what it takes to repair it?
My car is a 2010 and has just been delivered, so I am going through certain "as delivered" issues that I want to see how the seller (Aston Martin dealer) responds to before I comment on their overall service and responsiveness, which has so far been good.
I am comparing this noise vs. the light clicking from my SL550 V8 with the hood open. Its engine component noise was much quieter at 71,000 miles than this car is at 15,000.
Only my assumption of what I was hearing on that first V8V I was inspecting. After reading here about several having their idler pulleys replaced. It wasn't the consistent sewing machine from the valvetrain, it was the front of the engine.
Is anyone in the LA area with a Vantage that perhaps can compare?
I don't know if it's because I never noticed it before. There is somewhat of a light regular ticking-ish sound coming from engine that almost make it sound diesel-ish but not quite. You dont hear it inside rhe car but only standing outside next to the engine. Thing is I had the car pre inspected by two places one at the exotic dealer that had its own service center and gave me the inspection report and another Pre Purchase Inspection done at the Galpin Aston Martin dealer which rated the car in great condition other than the clutch will need replace in the future.
Ron
Haven't had my 4.7 since 2011, but my recollection is that there was a definite mechanical 'thrash' that was audible at low and medium engine speeds, before the exhaust note drowned everything out. Would never have described it as a 'ticking' noise, however.
and if you're gonna be in town near LA area, maybe lets grab coffee.
yeah, you're right, it does more resemble thrashing thank ticking. like a very consistent faint metal thrash. i guess that's just how these engines sound.
I live in LA (Encino) if you want to check mine out.
The clicking youre talking about about is likely the injectors. This is a common sound for almost all modern engines. I do notice that the 4.7 has a bit more valvetrain noise than the 4.3 it replaced. This is resolved by pulling the exhaust flap fuse.
Youre welcome to meet up to check it out.
I would be wary based on the oil filter problems people on this forum have had. I have a 4.3 with 115k miles and it is quiet as a merc. sedan after five minutes or five hours of driving. One might want to check if oil passages and heads were changed significantly from 4.3 to 4.7.
