Exhaust cutouts
Exhaust cutouts
Just wondering if anyone has done something similar on their AM? Majority of the time I love the quietness of the V8V but at some points, when I'd like to open the car up on an onramp per say, would like a moment of bliss
Has anyone installed something like an electric cutout on their AM? If so, where was the placement?
Habitual is talking about the valve on the muffler which is a whole different matter.
He is talking about cutouts just past the first set of cats and most cutouts are made universally, so as long as you got the correct size for your exhaust pipe diameter you should be good to go.
Do we know the oem pipe diameter after the first set of cats? Thanks randyb!
I actually looked into this and figured out a way to use a vacuum controlled valve instead of electric then hooked it up through the factory hardware to provide the vacuum source. A relay and remote.. You're in business. I've got a few of the valves around as well if you're interested. I was able to modify the vacuum pump on my car to function via a remote control and basically bypass the ecu control completely. If you decide to move forward.. I can help you with this if you're interested.
The vacuum controlled valves are much smaller and easier to package under the car.
Yes.. The pump is just like a little electric powered air compressor. It'll run and build/maintain pressure without the car running even.. You just need the ignition powered up. There's just a small modification within the wiring needed and then you can make it function completely manually via a remote control. There's a gentleman who sells a kit that plugs directly into the fuse 22 input within the fuse box and his kit also includes the remote and relay to operate the pump. You just need to make this change within the wiring to bypass the ecu operation of the pump which is what makes the valves open at certain RPM etc.. You need to bypass the ecu so you can operate the valves completely manually.
I'll dig up the info on this kit and post it back here.
Here's the gentlemans website whom I purchased the kit from. These are vehicle specific and come complete with everything needed.. It's a really nicely done piece and Clive is a great guy.
http://www.cccharger.co.uk
I'll post the instructions for the wiring modification I performed to make the original vacuum pump run manually via this kit with remote control. I have not completed my cutouts yet but I do have this portion of the process all figured out. I definitely wanted to use the oem vacuum pump and stay away from the aftermarket electronic cutout valves.. Primarily for packaging reasons. It's very tight under there and the vacuum style valves are much smaller than these electric valves.
I like the idea. let us know how it turns out. I have 2013 v8, took out my secondary cats & using quicksilver straight pipes & QS super sport muffler. Still at times i think I want to be loud. So this could be good option.
Exhaust cutouts are typically used to exit the exhaust under the car at some point before the mufflers. My idea is to to use the valves inline and then create some bypass pipes to circumvent the silencer totally but still have the exhaust exit out of the original tips. I hate the idea of just dumping the exhaust under the car somewhere.. No way.
My Ferrari has a set up like this as original equipment. The vacuum controlled valves control the flow of the exhaust completely around the silencer.. It sounds fantastic when those valves open up.
I have remote control kits in stock. Key fob operated. The factory exhaust is 2.5" after the cats (63mm).
If you want a valved exhaust setup that is a muffler bypass when open, we can make one no problem.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
I had these on my 65 GTO, they were ****ing awesome, you would open them up and it you could feel the sound pressure in your ears at idle!
we had it hard wired with a toggle switch just under the dash
(not me in the car, thats my mechanic)
