Service Nightmare Scenario - New Aston owner lookking for help!
Old Oct 24, 2017 | 10:10 AM
AstonNewbie's Avatar
AstonNewbie is infamous around these parts
Hi guys and gals!
I am the very proud owner of my first Aston Martin - a 2010 Vantage V8.
I wanted to draw on the collective knowledge of the board to see how to deal with some early issues I have experienced.
1. A few days after picking up the car, the emmissions light came on and I took it in for service and ended up changing the Purge Valve.
2. A few days after that while driving, the dash lit up like a Christmas Tree - ABS sensor, E Brake sensor, Traction Control Sensors, and a Red Triangle symbol all lit up. I took it back in, described what happened, and we end up doing two things -- replacing ABS sensor and going ahead and doing the annual maintenance. The last annual maintenance was Jan 2017 so we were a bit early.
3. After picking it up, I didnt even get 100 yards from the dealership before the emmissions light lit up again. I turned around and went right back in and was told that it may be the Purge Valve.
THE PURGE VALVE??!
Its in the shop now and they are trying to figure it out.
I am servicing currently at the only Aston dealer in Houston, and it seems like they are just 'spit-balling' and not really addressing the root cause.
Any help / ideas / referrals for other options in the Houston area would be appreciated.
Old Oct 24, 2017 | 02:47 PM
XJRS Owner's Avatar
Sounds like a weak battery.
Old Oct 24, 2017 | 02:50 PM
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
Probably a weak battery or bad CRM (if it's a convertible).
Old Oct 24, 2017 | 02:53 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Good call, and something that's not just wasted money if it isn't. You're probably still on your original battery so at 7+ years it owes you nothing and is due for replacement anyway.
Old Oct 24, 2017 | 03:13 PM
Thanks a ton - it is a Coupe.
New battery on order!
Old Oct 24, 2017 | 03:16 PM
5 Year Member
I'd have the dealer check the date on the battery just to verify it's the original.
Old Oct 24, 2017 | 03:17 PM
Redpants's Avatar
Also, welcome to the forum and to Aston Martin ownership lol
Old Oct 24, 2017 | 03:20 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
The emissions will also trigger with a loose or defective gas cap.
Old Oct 24, 2017 | 03:23 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Who did you order from? Sounds like the dealer.........
Order a Battery from REDPANTS or just buy the appropriate type and install yourself. REDPANTS has a video for DIY for a Vantage.
I would take that car out of the dealers hands asap. They already wasted your money on things most likely NOT needed at all. Why give them more.
Welcome to the forum. Aren't forums great!!! You had an issue with your car that a Aston Martin dealer couldn't help you with. But you join a forum, ask a question, and poof----your question and issue is answered within hours. So many helpful people on here. Hopefully you will be an addition to the members here and be able to help others in the future.
Old Oct 24, 2017 | 03:28 PM
5 Year Member
Hopefully the consensus is right, but it is a forum and advice is free so literally, you get what you pay for, and it's not always right
Old Oct 24, 2017 | 03:30 PM
lilseevs's Avatar
lilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud of
What are the specs on the battery for our cars? Just for future reference, I have a feeling my car is on it's original battery as well
Old Oct 24, 2017 | 03:59 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
My XK was known to be sensitive to battery issues. Why isn't the battery part of an annual service at some point?
Old Oct 24, 2017 | 04:19 PM
SheriffDep's Avatar
As Cpt Greg would say "a lot of Milf's have electronic things that are sensitive to battery issues also, its fairly common"
Annual Service----- I am willing to bet the AM battery is probably something like $300 or so. Ridiculous of course. But, to add that to the $900-1300 Annual Service costs, even at a one time per 3yrs would probably cause more headaches with customers than not having it in there.
Most people, even forum members would decline any type of battery cost from a dealer if they ever mentioned it. Its not until you have a battery failure or electronical issues that it is even brought up. However, in these cases its the first thing an owner should replace to solve a problem. Especially if a vehicle has sat on a dealers lot or showroom for over a month or two.
Old Oct 24, 2017 | 09:39 PM
5 Year Member
AM battery is $450 in my area. I'm having my done with the annual service because it's nearly 8 years old and I'd prefer not to get any gremlins if I can avoid them.
Old Oct 24, 2017 | 09:43 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
A battery maintainer can get you a handful of extra years for $100. But of course don't buy the AM branded one. The CTEK 3300 is an outstanding unit:
Amazon Amazon
CATTMAN
