Failed Dipped Beam Warning... Advice please
Old Nov 2, 2017 | 08:49 AM
Xler8nAMV's Avatar
Xler8nAMV is just really niceXler8nAMV is just really niceXler8nAMV is just really niceXler8nAMV is just really nice
Failed Dipped Beam Warning... (Fix Included)
Hello all,
Newer owner of an 07 V8 Vantage here. Yesterday I was driving and I got a Failed Dipped Beam Warning on my dash. The passenger low beam is in fact out. I spoke to Red Pants and with their current issues they could not help me source a new bulb. I was given the stock part number but is there a standard part number so I do not have to use factory replacements and can save a few bucks or I should stick with factory? Are there other vendors that I could contact? Lastly, is there any DIY instructions anywhere?
Thanks in advance for all of your input! This really is a great forum and as I learn more about the car I look forward to contributing as well!
Old Nov 2, 2017 | 09:19 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Halogen or HID Lighting?
You don't state which type of lighting you have; the bulbs/components are different.
If you have HID lighting, the ballast could be defective; that happened to me under warranty.
There should be spare halogen H9 and H11 bulbs in your toolkit.
Check your owners manual, as there is a lot of information there.
The D1S HID bulb appears to be available on Amazon, and it's only $60; list price $125.
Old Nov 2, 2017 | 09:46 AM
Danno62's Avatar
Danno62 is infamous around these parts
Here is what I found in the owners manual...looks to be H9 for main beam and H11 for dipped beam.
I think you might be able to turn the wheel inboard enough to get the panel off and reach in...I haven't tried it so....
Standard buld UNLESS you have HID...then it seems you are going to AM...
Old Nov 2, 2017 | 09:50 AM
Xler8nAMV's Avatar
I do have HID! Looks like I will have to climb in there and take a look to be sure! Appreciate the help so far all!
Old Nov 2, 2017 | 09:56 AM
Danno62's Avatar
From the Scuderia site...number 3 is the ballast, number 8 is the HID bulb...
Old Nov 2, 2017 | 11:16 AM
Xler8nAMV's Avatar
Well it looks like it is an HID! Are there any vendors you recommend that may have slightly discounted parts such as Red Pants?
Old Nov 2, 2017 | 11:29 AM
Danno62's Avatar
Amazon?
Amazon Amazon
Old Nov 2, 2017 | 12:02 PM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
Amazon can help you with that for a good price ($60)
http://amzn.to/2xPKz39
or you can get a set of chinese knock offs for $24 for 2
http://amzn.to/2AdHpYz
edit: oops sorry looks like dude above me got to it first!
Old Nov 2, 2017 | 12:10 PM
Xler8nAMV's Avatar
When I check the fitment on those links it says that it does not fit our cars? Am I missing something?
Old Nov 2, 2017 | 12:14 PM
sonies's Avatar
5 Year Member
they don't really support astons on amazon
the motorcraft thermostat shows its not supported, but it is
http://amzn.to/2zqrCsc
whats the worst case that can happen, you return it for free?
Old Nov 2, 2017 | 12:19 PM
Xler8nAMV's Avatar
Truth and astonparts.com lists the same part sooo. Good call!
Old Nov 2, 2017 | 12:29 PM
Danno62's Avatar
According to DonL's post from the owners manual it is the correct number...I wouldn't always go by Amazon's listing being accurate, especially with our cars applicability and it being in the Ford conglomerate era.
Old Nov 2, 2017 | 04:25 PM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
I got these from Amazon for my V8V, fits perfect and are a bit brighter.
Old Nov 6, 2017 | 09:08 AM
Xler8nAMV's Avatar
Well it was not the HID bulb so now I need to see if it is the ballast. Can anyone confirm the Philips 4061123 is the correct ballast for the 2007 V8 Vantage? Thanks all for all of your help!
Old Nov 7, 2017 | 09:55 AM
lilseevs's Avatar
lilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud of
I am actually having this issue as well but did not want to start a separate thread
My bulbs however are not out, but rather not leveling, the beams are not straight when driving at night
I am assuming that the relay controlling the leveling/"dipping" or fuse is out? I have a 2010 with factory HID's - any idea if/where the relay is or if it's a fuse?
