Power Steering Fluid
Old Mar 22, 2018 | 12:41 PM
flittlejr's Avatar
flittlejr is infamous around these parts
Have leftover from last Mercedes Power Steering Fluid. Need to top off my AM Vantage V8V. Says ATF only. Mercedes OK to use. Thanks Frank
Old Mar 22, 2018 | 02:06 PM
embdenb's Avatar
+1
If not, will any automatic trans fluid be acceptable?
Old Mar 22, 2018 | 02:12 PM
flittlejr's Avatar
Talked to dealer. Can't use Mercedes (too many minerals). Can use BMW, but AM says use CHF-115 PENTOSIN (Green Bottle). Funny name but dealer said lots of regular auto parts have on shelf.
Also coolant - Havoline Concentrate XLC also readily available.
Thanks for reply Fraank
Old Mar 22, 2018 | 03:35 PM
handyman2009's Avatar
Veteran: Canadian Forces
Couldn't find CHF-115 PENTOSIN but found CHF-11S PENTOSIN
https://www.amazon.ca/Pentosin-CHF-Synthetic-Hydraulic-Fluid/dp/B002WTHW26
Old Mar 22, 2018 | 05:38 PM
MRCW's Avatar
You could likely use the Mercedes fluid to fill your blinker reservoir. This fluid type is fairly generic for that use and should not cause any harm
Old Mar 23, 2018 | 04:41 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
I would check Rich at redpants website as he has all the correct fuilds or ones that match exact or better...
You could also ask Irish07 a member here.
I also thought under the sticky area it addresses all fuilds for our cars...
Good luck
Old Mar 23, 2018 | 06:13 PM
Jay Vong's Avatar
Jay Vong is infamous around these parts
not to derail the thread but how do you flush out the old ps fluid without using a machine.
can you disconnect the return line and start the car or does the fluid squirt out too fast?
Old Mar 26, 2018 | 08:23 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
See service bulletin for correct procedure
There is a service bulletin out for the Astons that don't have the Pentosin CHF-11S fluid as OEM (i.e. V8 Vantage up to C13358, DBS up to E01351 and DB9 up to A12418).
It details how to flush the old fluid out (Texaco Cold Climate) and I presume it would be the same for flushing any fluid from the PAS system.
There is an additive required when changing fluids to Pentosin; I'm curious if Redpants stocks the 50 ml of Lubrizol needed? [4G43-24-11082]
Thanks to whomever posted the service bulletin earlier!
File Type: pdf
Last edited by DonL; Mar 26, 2018 at 08:48 AM. Reason: Added Texaco Cold Climate and Early Vantage Owners Manual page
Old Mar 26, 2018 | 08:36 AM
bunob's Avatar
bunob is infamous around these parts
Hi all,
I have a V8 Vantage from Feb 06.
Can I flush my old fluid and replace it by the Pentosin CHF-11S one ?
Do I need to add the 50 ml of Lubrizol [4G43-24-11082] ?
Old Mar 26, 2018 | 08:50 AM
DonL's Avatar
Originally Posted by bunob
Hi all,
Yes and yes; that's what the service bulletin was written for!
Old Mar 26, 2018 | 12:51 PM
bunob's Avatar
Thanks DonL
Would anybody have reference of the Lubrizol product ?
Maybe 6178 like this : https://www.ebay.com/itm/New-Genuine-Power-Steering-Fluid-Additive-50-ml-Bottle-Lubrizol-6178-/362191754681
Or this one https://www.ebay.fr/itm/GENUINE-JAGUAR-X-TYPE-POWER-STEERING-ADDITIVE-C2S48887/332221446386?hash=item4d59f0f8f2:g:kNQAAOSwnDZUFue Y
Old Mar 26, 2018 | 05:21 PM
J doubleU's Avatar
Jaguar is the same, I'd use it.
Old Mar 27, 2018 | 12:49 PM
bunob's Avatar
Thanks J doubleU
Old May 3, 2020 | 11:10 PM
Calcifer33's Avatar
Calcifer33 is infamous around these parts
Sorry to revive this thread, but what did/would any of you use for a plug for the return port of the PAS reservoir (step 8)?
Old May 4, 2020 | 11:14 AM
Calcifer33's Avatar
Originally Posted by hsm precision
I would look for the same diameter hose, and put a bolt into it (maybe hose clamp to keep it from dripping).
Or, pick up a powdercoating plug kit - you could use the silicone plug to stick into the outlet.
Matt
I like that silicone idea. Thanks!
