water pump...
Old 09-12-2018, 07:22 PM
Argus's Avatar
Argus will become famous soon enough
water pump...
Do any of you change the water pump when you do the sepitine belt? What do you get a rebuild kit for water pump?
Old 09-12-2018, 07:57 PM
J doubleU's Avatar
Rebuild? If your thinking about a pump replacement, buy a new pump....
Old 09-13-2018, 01:14 PM
astonChap's Avatar
astonChap will become famous soon enough
hey Argus,
I had a serpentine belt replaced last year due to some cracking spotted in the belt - water pump was replaced - think it was a few hundred from the local AM dealership.
-ac
Old 09-13-2018, 05:13 PM
Vantagelvr's Avatar
Vantagelvr will become famous soon enoughVantagelvr will become famous soon enough
Originally Posted by astonChap
hey Argus,
-ac
Hi sir hows the Aston running .......all good can you just check the oil for me .........sure pop the hood would you pls , shes a quart low better bring her in for a new engine .....do you have a credit card number pls
Yes sarcastic but why change parts just coz your in there . If the pump isnt leaking or noisy why ??
Old 09-18-2018, 06:22 PM
astonChap's Avatar
Hey Vantagelvr,
Agree with the sentiment - I was surprised when it was suggested, however, I think it's more to do with "while I'm down there" type logic. Considering the damage that could happen to the engine if the water pump was affected by a bad serpentine belt etc - I had no issue in replacing it (other than adding a few dollars).
Old 09-18-2018, 06:45 PM
J doubleU's Avatar
Both the belt and the pump will go 100k miles. Well the belt will squeal before then, but not wear out. Plus the pump is very reasonable.
Old 09-19-2018, 08:10 AM
MRCW's Avatar
Hey Vantagelvr,
I'm a big fan of "while I'm down there" logic. 😉
Old 09-19-2018, 09:16 AM
Scottiejo's Avatar
Scottiejo is on a distinguished road
Although this may make sense with some things, mostly consumable items; I'm not a proponent of changing a known good component for an unknown. Especially a dynamic component.
I'm in aviation and this is not a regular practice on aircraft. Obviously cost prohibitive but also could cause other maintenance induced failures.
v/r, Scottie
Old 09-19-2018, 10:59 AM
MRCW's Avatar
v/r, Scottie
while i would generally agree with you in principle... components that are known wear items, or parts that would generally be removed during the course of other work could and should be replaced, especially if it's an accessory item like a water pump.
obviously you wouldn't tear apart an engine to replace parts that 'might' fail...
Yves
03-27-2014 05:03 AM
pureporsche
09-04-2013 11:06 PM
FAST FWD
08-20-2010 11:31 AM
Quick Reply: water pump...
