DB11 - DBS Superleggera
Old Oct 19, 2018 | 06:13 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
The new DBS and the DB11 both have. 5.2 V12. The DBS has 715 hp and the DB11 has 600hp. Is the difference just in the tune or are there fiscal differences in the engines?
Old Oct 19, 2018 | 08:01 PM
J doubleU's Avatar
Everything I have seen points to tuning. Was told the gearbox is changed for the extras.
Old Oct 19, 2018 | 10:00 PM
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
I think the suspension and brakes may also be different
Graze
Old Oct 20, 2018 | 07:49 AM
embdenb's Avatar
The engines are the same. Increasing horsepower in pressurized engines in a lot easier than non pressurized engines. Generally this is done managing the wastegates and modifying the ecu.
My understanding is that, due to the size of the turbos, Aston has reached the horsepower limit on this engine.
Old Oct 22, 2018 | 05:56 AM
Phil57DBS's Avatar
5 Year Member
Phil57DBS is infamous around these parts
Standard DB11 on Dyno test = 554hp
with VAP tune = 604hp
with VAP tune + 100cells cat = 626hp
Standard DB11 on Dyno test = 490ft-lbs = 664Nm
with VAP tune = 600ft-lbs = 813Nm !!!
with VAP tune + 100cells cat = 832Nm !!!!!!
https://www.boostaddict.com/content....wnpipes-127WHP
Old Oct 22, 2018 | 12:42 PM
Gene G's Avatar
I just wonder if you could download the tune from the new DBS and then upload it to the DB11. Anyone know if that would be possible?
Old Nov 4, 2018 | 01:18 AM
AWV12's Avatar
AWV12 is infamous around these parts
Test drove the DBSS Coupe yesterday.....what an impressive car!
Much more different from a DB11 than you would expect (a bigger difference than between a DB9 and the previous DBS). It is not only the extra horse power and torque (that is immense!) but also the handling, steering, suspension and (exhaust) noise........all much more involving. In GT mode you can drive it through town easily, and in Sport (or Sport+) things get really wild, especially if you drive it in manual mode (using the flippers). Braking is also very confident (a step forward from the previous DBS, that also has CCBs).
The only downside is the "lazy" ZF transmission, especially when downshifting, you really notice the delay. Strangely the downshift sound is right on (with perfect blips, burps and murmles from the exhaust) but the downshift itself takes more time than these sound bites (also in S+). A DSG transmission would make this a perfect car imho! (or a manual 7-speed gearbox, but we probably can forget about that.....). Maybe a software upgrade can make this shifting faser / more suitable to this extreme good car?
Looks are of course superb: outside the showroom you see how beautiful it is. One of the most beautiful cars out there currenty imho.
It is really a GT Sports car that could be used every day, but also for some serious driving around mountain roads or a track. For real track driving fans, you are probably better of with a Vantage, but for GT lovers like me, it is (almost) the ultimate car out there now.
Waiting for the Volante to hear the sound of the V12 in open air!
Old Nov 5, 2018 | 10:38 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
The DB11 is a soft GT car that has around 600hp.
The DB11 AMR is the same car but different suspension, some larger carbon fiber bits, and a different tune which brings that to 630HP or so. Much sportier than the regular DB11 and from what I am told drives way different, and more like sports car.
The DBS is a totally different car with multiple personalities. It has 700hp, much more of the car made from carbon fiber, carbon ceramic brakes, and much different suspension setup. This is supposed to be world class.
Velocity AP does have a tune---about 700hp out of the 5.5L V12 twin turbo motor. I know the tune in my RRS that velocity did, due to the torque and power curve changes the way the transmission worked changed a bit. So not a dedicated tranny tune, but it did change it. Depending on the ZF unit, Velocity may, again may, be able to adjust the parameters on the transmission if needed.
Most manufacturers start with a series of cars with a certain new motor. ie.....Jag's 5.0L V-8 supercharged. They put it in all the high performance vehicles with 510hp. Then such as the Range Rover Sport (510HP) they sell the SVR version, and say wow it has 30hp more. Meanwhile with just a good tune the motor by Velocity AP can have 600HP. So as Aston has done, they de-tuned the 5.5L motor so at its base it has the 600hp. Now they can increase by Tune's the HP for newer models, AMR versions, and still use it in it top model with max HP.
Go with larger turbos and a tune, that motor could see significantly more HP without drivability issues. Good for everyone.
Old Nov 6, 2018 | 08:56 AM
AWV12's Avatar
Will be interesting to know if/when VAP have a tune for the 725 BHP DBSS available and how many BHP and torque that will result in!
Old Nov 7, 2018 | 12:16 PM
Gene G's Avatar
I would doubt that they can get much more out of the DBS with just a tune. The DBS and the DB11 engines both have the same part number. The difference in power is just in the tune.
Old Nov 7, 2018 | 01:01 PM
Zettinger's Avatar
Zettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of light
That is funny. Per Phil's data, VAP tune would downgrade the DBS from 725 to 604 HP.
Old Nov 7, 2018 | 05:33 PM
SheriffDep's Avatar
VAP already has the tune to match the DBS numbers. They have had it for awhile now
Now I was told by a Brand Manager who knows his stuff that 800HP was the max for that motor. He did not know or elaborate if that required a change in the turbos. I also have heard the DBS and VAP tunes max that motor out with its current sized turbos. So not sure what the reality actually is.
I would suspect, that a full change of exhaust, larger turbos, and then a good tune could net 900+ hp easily without risking the motor. Most manufacturers stay well within the bounds of safely giving power.
Stuart with VAP could easily tell us.
Old Nov 13, 2018 | 06:35 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
"Risk".... how are we defining that. A or B?
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
cmargosi
Sep 21, 2018 07:25 AM
mjanis
Aug 19, 2018 10:33 AM
DonL
Aug 3, 2018 08:25 PM
007JB
Sep 28, 2017 04:24 PM
