VelocityAP Airbox Delete Kit for V8 Vantage, V12 Vantage, DB9, DBS, Vanquish, Rapide
Old Oct 16, 2019 | 02:46 PM
  #61
bolteon's Avatar
5 Year Member
bolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud of
Might be funny to you, but it's not something I would personally consider.
It wouldn't have been much more effort to weld on a small pair of circular clamps and have it be held in place properly vs something that looks like a prototype. Would help with the cost justification in my opinion.
Old Apr 2, 2020 | 12:17 PM
  #62
AMR248's Avatar
AMR248 is infamous around these parts
I have an engine fault code on the dash after i installed the GT4 kit. 2/8 cylinders get to much air! I also have the tune. Exhaust system is stock. Any idea?
Old Apr 2, 2020 | 12:26 PM
  #63
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
"Too much air" - what this means is that there is air getting into the engine somewhere that has not been measured by the Mass Airflow sensor. For it not to be measured by the sensor it means the air is getting into the intake system somewhere between the Mass Airflow sensor and the engine.
Since you installed our kit, which mounts the filter before the mass airflow sensor, I would suspect you have probably inadvertently pulled something loose in the intake, and created an air leak. Check all your connections, check your clamps, if you had the valved airboxes, check that your vacuum lines which would operate the airbox are capped/plugged effectively, or if you removed them, that the port on the intake is capped effectively.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Apr 2, 2020 | 01:35 PM
  #64
AMR248's Avatar
Thank you!
Old Apr 17, 2020 | 11:08 AM
  #65
AMR248's Avatar
Today i read the codes. Initially bank one ran too lean. Refixed the hose at the intake manifold (was slightly loose). Driven for 20 min. No fault. Restarted the car, drove for 5 min. -> Fault. Now Both banks too lean. Refixed the hose of the left intake duct, which also seemed to be losened. Drove the car for 20 min. no fault. Restarted the car After 5 min Pause. -> both banks run to lean. Cleared the code, drove 20 min. , no fault. Ideas? 🤷‍♂️
Old Apr 17, 2020 | 11:16 AM
  #66
I would take the car to a mechanic and have them smoke test the intake system.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Apr 17, 2020 | 10:57 PM
  #67
AMR248's Avatar
Are dirty and old (they are the 1st, car is MY07) MAF sensors underrepresenting intake airflow also a potential cause?
Old Apr 19, 2020 | 08:59 AM
  #68
AMR248's Avatar
Stuart was right. A tiny gap between the MAF duct and the intake hose caused P0171 and P0174 in my car! Thank you!
Old Apr 22, 2020 | 01:46 PM
  #69
AMR248's Avatar
The fault turned back again 🤮 I now changed the hose clamps. Hopefully this works.
Old Apr 22, 2020 | 01:57 PM
  #70
bolteon's Avatar
5 Year Member
Originally Posted by bolteon
Are zip ties really what is being suggested?
I would think that's something you'd find on a Mustang, not an Aston.
It should come as no surprise, that anything being secured with a piece of plastic like a zip tie or a zip clamp, is substandard to a proper (read: metal based) clamp/attachment system.
But hey... what do I know.
Old Apr 22, 2020 | 02:17 PM
  #71
AMR248's Avatar
those clips were from factory. The VelocityAP Intake is awesome!
Old Apr 22, 2020 | 02:23 PM
  #72
Are you suggesting that the zip ties are causing an air leak?
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
  #73
bolteon's Avatar
5 Year Member
Oh I'm sure, but the point still stands.
Old Apr 22, 2020 | 03:00 PM
  #74
AMR248's Avatar
unless the contrary is proven it was my fault, I guess 🤷‍♂️
Old Apr 29, 2020 | 08:42 AM
  #75
AMR248's Avatar
I checked the entire intake system and did the smoke test. No vacuum leak. Then I changed the MAFs. Fault again showed up on the dash.
I then did some ECU logging with the car on idle
Fuel System Status Bank 1 = 2
Fuel System Status Bank 2 = 0
Intake Manifold Pressure 34 kPa
Short term fuel trim bank 1 = -4 to +6
Long term fuel trim bank 1 = 3
Short term fuel trim bank 2 = -12 to -2
Long term fuel trim bank 2 = 13
Mass air flow 5.83 g/s
Throttle position 12,941176 %
Location of o2 Sensor 51
Then I reflashed the original ECU file and the values were as follows:
Intake Manifold Pressure 54 kPa (34 after CEL came one)
Short term fuel trim bank 1 = -1 to 5
Long term fuel trim bank 1 = 0
Short term fuel trim bank 2 = -1 to 4
Long term fuel trim bank 2 = 3 (went up to 11 after the CEL came one)
The car did again throw a CEL during the first drives after reflashing the Stock Software but OBD reading showed both 02 sensors stuck in lean position and P2073 Throttle body position / MassAirFlow and both Banks running lean.
Is this a hint for the 02 sensors being damaged and giving the car a false „lean“ signal or did I just not find the leak? 😭
captain Greg
May 1, 2026 04:20 PM
Denny 6.53
Jan 9, 2018 05:23 PM
Stuart@VelocityAP
Jan 11, 2017 02:19 PM
blayne
Dec 1, 2009 03:56 PM
jr_spyder
Aug 25, 2008 10:50 PM
