Need help with lower radiator hose - DB9
Old Jan 5, 2019 | 02:18 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
My lower hose busted and I am traveling, anyone know what size the hose is (diameter) and what coolant is compatible that I can get at a auto parts store?
Old Jan 5, 2019 | 05:08 PM
W126C's Avatar
W126C is infamous around these parts
http://www.astonmartincarparts.com/diagram/astonmartin/db9-2004-2012/engine/coolant-hoses/151-668-23906.html
I can't find my reference data on size etc. I'll check another computer and see what's on it. Doesn't sound like an easy road side fix. Good luck.
Regards,
Old Jan 5, 2019 | 05:47 PM
randyb's Avatar
Yeah, I saw that. It does not show the short hose that actually goes to the radiator.
Old Jan 11, 2019 | 09:44 AM
randyb's Avatar
I got a hose repair kit and fixed my leak and for those wondering the inside diameter is 2". The repair kit I used came with a 1 3/4" connector, which I used and just clamped it down. Got the kit from Advance, also ordered new hoses which was just over $400 for all hoses (Ouch).
Old Jan 11, 2019 | 09:57 AM
randyb's Avatar
And I used Prestone Extended life, it is very close to the oem formula.
Old Jan 11, 2019 | 10:05 AM
astonChap's Avatar
astonChap is infamous around these parts
good to know randyb - glad you got it resolved, albeit a tad pricey!
Old Feb 27, 2019 | 10:50 AM
randyb's Avatar
So I got the new hoses and quickly found out they were for the 08+, so I got a 20" flexible hose from Napa and got the car back on the road. They had 17" and 24" also, but the 17 was to short and the 24 was to long. You could make the 24 fit, it would just be resting on the skid plate. I used Prestone Asian/ European formula 50/50 coolant. You will need 4 gallons, because the car takes just over 3 gallons and flush out the old coolant.
vman932
Dec 21, 2024 10:43 AM
jhuang25
May 26, 2009 01:18 PM
N1_kT
Dec 2, 2008 12:06 PM
TXGold
Feb 25, 2008 04:02 PM
rcalcaide
Nov 30, 2006 11:51 PM
