Retrofitting SAT NAV on DB9
Subscribe
Mar 4, 2019 | 09:39 PM
I am currently having a 2005 DB9, which sadly doesn't come with a SAT NAV. Even though I have heard so many negative comments on the SAT NAV, I still hoping to retrofit one to the DB9, so that I can also install a phone mirroring to the screen and can maximize the utilization of the screen. Does anyone has actually try to retrofit the SAT NAV before or done something similar? May I have advice on what components is required for installing the SAT NAV and makes it works. So far, I have got a second hand screen, SAT NAV DVD player and the controlling ****. I have had them all plugged in, but the screen just doesn't rise up and I can hear that the DVD player is playing. Is there anything else that is required for making the system works, e.g. hardware and/or software maybe?
Reply
Mar 5, 2019 | 04:44 AM
I've never understood the reason to mirror your smartphone to a screen that you cannot touch or use.
I have nav in my vantage but have never used it. Instead I use a smartphone with a simple mount easily usable if needed and have a rear view mirror monitor for front and rear view camera feeds...
seems like an enormous expense and work for old outdated technology.
good luck!
Reply
Mar 5, 2019 | 01:58 PM
DON'T!!!!
It is an obsolete system and a BIG PITA to use.
What you need, new entertainment main wiring harness for Nav, Nav module, Nav specific fiber optics cable, dash harness with Nav connector, Nav amp, plus things I am missing. Entertainment module would need to be reprogrammed to look for Nav module. New ski slop and display.
You would be in $5-7,000 and this might be on the low side.
Reply
Mar 5, 2019 | 03:24 PM
This is your opportunity to install an aftermarket unit that will wireless connect to Apple CarPlay (or the Android equivalent.)
There are a number of manifactures on the market. Instead if the rotating factory screen, install the screen permanently at a slight angle.
Thats what I would do
Reply
Apr 26, 2019 | 09:54 AM
@embdenb Do you have any examples of units that might work with a 2012 Rapide?? My screen has just conked out and I am in no mood to pay the $1600 to replace it!
Reply
Apr 27, 2019 | 06:38 AM
Quote: @embdenb Do you have any examples of units that might work with a 2012 Rapide?? My screen has just conked out and I am in no mood to pay the $1600 to replace it!
I was thinking of a new self contained navigation unit in place of the existing.
Reply
Apr 27, 2019 | 10:18 AM
2012 is a Garmin system, are you guessing that it's the screen at fault? Usually a connection or component that fails.
Reply
Apr 30, 2019 | 02:47 PM
I ditched the OEM screen in all (480 pixels is sooo 2000's) and retrofitted a Garmin HD navi unit. See more of it here: https://www.6speedonline.com/forums/...ml#post4709719
Reply
Subscribe
