Will oil siphon work to remove most oil?
Old May 15, 2019 | 10:56 AM
goto35's Avatar
goto35 is infamous around these partsgoto35 is infamous around these parts
I know we have a dry dump. I only drive 2 to 4K miles a year. Just thinking instead of getting a oil change every year I can just siphon oil myself from top and refill oil. Will dry dump allow me to siphon oil?
Old May 15, 2019 | 12:02 PM
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
You could theoretically sipohon the oil out of the reservoir, but much easier to just drive it up on some boards/ramps, remove the undertray, and drain it from underneath. A yearly oil change is cheap insurance and I wouldn't skimp on it. Not a whole lot of oil comes out of the back two plugs so you could probably skip those, but I'd drain the reservoir and the first plug and change the filter.
Old May 15, 2019 | 12:04 PM
J doubleU's Avatar
It's easy enough to do a simple oil change, why would you want to do it from the top? and make a mess. The dry sump drains back to the engine, you would spend more time most likely doing it from the top. Where is your mobile mechanic that you used to use?
Old May 15, 2019 | 12:49 PM
goto35's Avatar
Ok I'll keep doing it the regular way.
Just thinking with siohon I won't need anyone else and I could do it myself.
Thanks for the response.
HotRodGuy
Jan 30, 2016 04:18 PM
floatingkiwi
Oct 10, 2013 09:33 AM
doc911
Jul 7, 2007 01:06 AM
DAVE W
Aug 19, 2005 02:55 PM
