Tranmission pipe kit 4g43-31-10938
Old May 15, 2019 | 04:59 PM
bidcleary's Avatar
bidcleary is infamous around these parts
Hi
Has anyone any idea on what the labour time would be to replace this kit which does include the cooler? Thanks😀
2005 DB 9
Old May 15, 2019 | 08:28 PM
J doubleU's Avatar
Have you called a dealer for a price quote? Many independent shops will beat the dealer install price to get the job. Hard to guess what would be the cost/time in your area to change the lines and cooler.
Old May 16, 2019 | 06:08 AM
bidcleary's Avatar
Yes, I was expecting 8 hours which would include an oil change, however, that time has doubled, as I want to be fair in paying for their time spent I would like to be sure what is acceptable for work done. 😁thanks
Old May 16, 2019 | 06:19 AM
J doubleU's Avatar
8 hours with an oil change sounds like a fair price. 16 hrs. Is highway robbery.
Old May 17, 2019 | 04:48 PM
DB IX's Avatar
DB IX is infamous around these parts
I changed just the trans cooler a couple of weeks ago. Is a big job. Local garages here quoted £1800 (I’m in London UK). Main dealers even more.
Front and rear undertray comes off. Wheel arch liners and front bumper also. You will have rusted bolts that will snap.
I didn’t change the actual lines because they were not leaking but I think that is not too hard. Good access from underneath.
Problem is refilling and checking auto fluid level. Have to run up to around 30-50c. The issue is the hot exhaust pipe in proximity to the fill plug..
can be done one without removing the exhaust pipe as the workshop manual states. Just remove heat shield and you should have enough access.
bad107
Sep 8, 2011 09:48 AM
ekim200
Aug 29, 2011 05:23 PM
ishmerc
May 11, 2009 08:09 PM
madru17
Apr 16, 2008 07:05 PM
LIL RAJA
Cayenne 955/957
Feb 28, 2005 10:37 AM
