2010 DBS ball joints, driver seat fold motor (to access back seat) repair
Old Jun 6, 2019 | 07:54 PM
4FordFamily's Avatar
4FordFamily is infamous around these parts
Hello all,
I have questions on three repairs.
1) The ball joints have just a little bit of play in them, how much is this to replace? Hard to do?
2) The motor that moves the seat up for “rear seat access” doesn’t work, or the switch doesn’t work. How bad?
3) The plastic back of the flip up navigation screen is cracked. It looks like the plastic piece comes off, I imagine a black vinyl covering would suffice as well. This common?
Old Jun 7, 2019 | 08:53 AM
XJRS Owner's Avatar
There is no back seat access motor.
Old Jun 7, 2019 | 09:42 AM
chriscmore's Avatar
5 Year Member
chriscmore is just really nicechriscmore is just really nicechriscmore is just really nicechriscmore is just really nicechriscmore is just really nice
I think he's referring to the powered seat release. The pull-loop under the headrest will do the same thing, but it's a valid question for his shopping for a new ride.
Old Jun 7, 2019 | 09:45 AM
OK, I paid for an inspection which is where these items came about.
Correct, that's exactly it. So if I can pull the loop instead I don't care much. Thank you for that!
Any idea on the ball joints? That has me a bit worried
Old Jun 7, 2019 | 09:47 AM
chriscmore's Avatar
5 Year Member
By "back of the flip up navigation screen" are you referring to the domed dashboard assembly? They frequently have damage to their wood surface, so some people refinish them in various paints or wraps. I had my wood redone. Getting the larger perimeter piece and the included backside of the navigation display off is super easy, so if you have ideas on what you want to do with it, that's not a big deal.
If you're referring to the backside of the display that's covered by the dash panel, then it's not visible and various reattachment techniques can be used such as velcro. Normally, there are two long spring clips, which are easy to unlatch in order to remove the top dashboard assembly.
I consider the flip screen a non-issue since I'll never use it. It can never be as up do date as your phone. As long as it functions (for resale value) and looks perfect in the closed position, I'm happy.
Old Jun 7, 2019 | 09:48 AM
chriscmore's Avatar
5 Year Member
No idea on the ball joints. I have a clicking in my '11 DB9 when steered hard (e.g. parking), so I'm not sure where to look for that. The AM dealer in Minny couldn't find a problem and lubed things, but it's getting worse.
Old Jun 7, 2019 | 10:10 AM
https://www.ebay.com/itm/Aston-Marti...-/183481671580
Does this look like the right ball joint product?
Also, here's a photo of the back of the screen (when down you can see the cracks)
Old Jun 7, 2019 | 10:20 AM
J doubleU's Avatar
That is a tie-rod end (it is a type of ball joint) Usually when someone says ball joint its the upper or lower ball joints on the A-arms. Those are a wear item but not on cars that have low miles and have been driven nice. What is the mileage and who did the inspection? AM dealer or an independent shop. The navigation panel is a complete assembly meaning replacement of the whole panel. I would source a replacement and pick anything but piano black, they are prone to cracking after a few years in the elements.
Old Jun 7, 2019 | 10:34 AM
Damn shows you how mechanically inclined I am!
It was an independent on-site inspector. A “little bit of play at low speeds on big bumps was barely noticed”. They assumed it could be the ball joints.
Ouch on the screen, that sounds expensive as heck!
Old Jun 7, 2019 | 10:38 AM
Mileage is 20k. I am guessing it was driven “spirited” given the fact that the tires were replaced at 15k miles and now at 20k they have 40% tread life. Car needs alignment as well.
Old Jun 7, 2019 | 11:15 AM
J doubleU's Avatar
Have it aligned and ask them to check for any "WARN" parts and see if they come up with an issue. I'll bet there is nothing wrong.
If you look at Aston Bits () com they have a new piano black for around $700+ shipping. to replace existing.
Old Jun 7, 2019 | 02:34 PM
Thank you, I will do just that!
I wonder which suspension mode was activated at the time he came to his conclusion
Old Jun 7, 2019 | 06:44 PM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
That car doesn't looked "loved". I would pass. Plenty of others out there
Old Jun 7, 2019 | 08:57 PM
That ship sailed, the price was right. I hope you’re wrong and it turns out OK LOL.
The mechanics are good other than the potential ball joints which they weren’t alarmed by (independent inspector). The guy owned several Aston and had it serviced at one dealer and it’s a one owner car. It has its highs, but yeah I would have taken better care of it.
Vantage mannen
Nov 8, 2017 11:18 AM
FAST FWD
Feb 19, 2013 09:23 AM
rcarpi2
944 Turbo & Turbo S
Nov 30, 2009 11:08 AM
Dscott
Apr 11, 2008 03:34 PM
