Love you guys...need some love back PLEASE
I have always been an American Muscle Car guy. Built them, restored them, modified them, raced them in 9:20 class etc. However, I have always wanted what I would consider an, “EXOTIC”. I believe that the Aston Martin is just that. I ran across an auction and got what I believe was a good deal on a 2007 Manual V8 Vantage. When I bid on it and won, they stated that it ran. When the trucker dropped it in front of my house, he said it ran. He said he pulled it on his hauler. I have not yet heard it run.
He stated that it started up with a charge but there was some serious noise in the engine. Well, knowing that these things have starvation issues with their dry sump systems, that scared me a little. However, not scared enough to run from it.
So, I tried to jump and charge the battery that was there…nothing. I went and bought a rather expensive battery for it and it cranks and cranks, wont start. I decided that I would buy a decent computer as my older scanner just was not cut out for it. I bought a brand-new code scanner, a rather nice one.
What I would like to do is drop the report here and see if there is anything that you, the obviously knowledgeable and intelligent folks that have helped so many on here, might be able to see a common thread among the ball of yarn I have acquired.
I would love and appreciate any and all information that you would offer on my behalf. Just PLEASE, don’t tell me to crush it, I just cannot do that. It is a rather nice car.
THE REPORT:
Vehicle Information
Year: 2007
Make: ASTONMARTIN
Model: V8 Vantage
VIN: XXXXXXXXXXXX05553
ODO: 80979 miles
Vehicle Software Version: V10.40
Diagnostic Application Version: V5.00.027
Diagnostic path: Automatically Search > Health Reports
Test Time: 2019-06-27 18:22:22
Tester: XXX
Customer Name: XXX
Inspection Result
CEM-HS (Central Electronic Module (High Speed CAN)) 4 problems exist
1.3A00 Redundant Code - Please Ignore
2.DE49 Redundant DTC - Please Ignore
3.DF11 High Speed CAN - High Side Open Circuit.
4.6C44 Redundant DTC - Please Ignore
CEM-LS (Central Electronic Module (Low Speed CAN)) 10 problems exist
1.6C28 Redundant DTC - Please Ignore
2.6C06 Central Locking Passenger's Door Failure.
3.6C07 Central Locking System Failure.
4.6C08 Central Locking System Failure.
5.6C14 Redundant DTC - Please Ignore
6.6C15 Redundant DTC - Please Ignore
7.6C16 Redundant DTC - Please Ignore
8.6C05 Central Locking Driver's Door Failure.
9.6C13 Redundant DTC - Please Ignore
10.DF01 Low Speed CAN - High Side Open Circuit.
DIM (Driver Information Module) 1 problems exist
1.E003 Network Identification Error.
ICM (Infotainment Control Module) 3 problems exist
1.DC02 MOST Network Not Locked.
2.DC01 Ring Break Detected.
3.1A58 Global Positioning System Module Node - Not Alive.
AFM (AM/FM Tuner Module) 1 problems exist
1.0001 Redundant DTC - Please Ignore
AUD5 (Audio Amplifier Module) 7 problems exist
1.0001 Internal Error In The AUD. DSP Communication Error
2.0002 Open Circuit On LF Speaker Output
3.001C Open Circuit On C Speaker
4.0003 Open Circuit On RF Speaker Output
5.0004 Open Circuit On LR Speaker Output
6.0005 Open Circuit On RR Speaker Output
7.001D High Temp On MOST FOT
SUB5 (Sub Woofer Amplifier) 3 problems exist
1.0001 Internal Error In The SUB DSP Communication Error.
2.0002 Open Circuit On Speaker Output Coil1.
3.001D High Temp On MOST FET
PAM (Parking Aid Module) 1 problems exist
1.C1744 Front Sounder Circuit Failure, Short To Ground Or Open Circuit Detected When Speaker Off
HLM (Headlamp Levelling Module) 1 problems exist
1.B1318 Battery Voltage Low
BCM (Brake Control Module) 4 problems exist
1.0115 Steering Angle Sensor CAN Timeout.
2.0100 Engine Control Module CAN Signals Missing.
3.0058 Brake Control Module - Over Voltage.
4.0057 Brake Control Module - Low Voltage.
The following systems are OK:
1.RCM (Restraints Control Module)
2.MMM (Multi-Media Module)
3.GPS (Global Positioning System)
4.MP1 (Media Player Module)
5.SAS (Steering Angle Sensor)
Again, I would appreciate any and all help!!
THE REPORT:
Vehicle Information
Year: 2007
Make: ASTONMARTIN
Model: V8 Vantage
ODO: 80979 miles
Tester: XXX
Customer Name: XXX
Inspection Result
Since it doesn't start, why is there no engine management codes? Have you tried clearing all the codes as there were numerous faults from low battery and jumping it to try to start. Do you have remote key fob for it? Have you tried lick and unlock with everything closed?
Need to connect the scanner to the other OBD port. These cars have 2, right next to each other. 1 port is for the powertrain modules and 1 port is for the body modules. Looks like you read out the body modules.
I am unsure why there is no EMC's. I had tried to clear the codes and it keeps coming back with the same response. Frustrating for sure. I do have ONE fob. I have tried to lock and unlock with everything closed as I have read on here that is a thing. However, it has not proven to help. Is there any code in there that would stick out to you that would be, lets say, an initial problem that would bring the rest of them up?
I know I do not have the battery reset button that I have seen a lot of talk about. So, in saying this, I imagine that this is an auto reset with the locking and unlocking you are referring to.
I did not think about the inertia switch. However, if it were an inertia switch, what else would not be working? Would everything work except for starting? I know my tach also seems to be stuck or not returning to 00RPM. What is the typical position for the enertia switch?
Ha, you know, it had already crossed the mind; since I come from that school. I would like to see if I can get it going how it is, but it is to completely out of question.
EMS (Engine Management Module) 1 problems exist
1.P1000 System Check Not Completed Since Last Memory Clear
Looking at your first post again, I'm wondering if you have a wire disconnected or damaged? There are several CAN bus errors, and I think if the CEM can't talk to the engine ECU, the car won't be allowed to start. The majority of the errors point towards open circuits.
It would help make a list of everything in the car that works, and what doesn't to help tie in where the break might be (lights, horn, wipers, fuel flap button, door open indication)
Do you have any history of the car (accident maybe?) Odd that it would stop running though. Stupid question, but is there enough gas?
~As far as the accident question, it had a very light front end tap. There is a tiny crack in the front drivers fender and one of the bars in the grill was bent.
~I will make a list of all that works and what doesnt. I will post that later. That is actually a good idea. Do you happen to know that if there was a tripped inertia switch, if that could be the culprit? Perhaps shuts down certain circuits such as the fuel module and pump. I will also double back on ALL the fuses as well.
Thanks and I will post later.
Since you have no engine codes, and it cranks you should have everything to run, I would definitely remove the fuel supply line @ the RH side of the rail (quick connect) fitting and make sure you have fuel. With 80k and sitting for who knows how long, chance the pump has crapped out?
This ^ If your not communicating on CAN low or high then your fuel pump will get nothing via CEM. I had a similar CAN error on my CEM and got the engine started by jumpering the fuel pump relay at the CEM. I'll see if I can dig out any details I might have noted.
Edit: Added Picture
Aston Martin Vantage V8 - Fuel Pump Relay
