Key Fob Programming
Old May 10, 2022 | 02:37 AM
  #46
chrzesm's Avatar
5 Year Member
chrzesm is infamous around these parts
Or the seed code attached to the key is somehow wrong. Unlikely, however possible.
Old May 10, 2022 | 02:43 AM
  #47
a102768's Avatar
a102768 is infamous around these parts
Yes, if I can prove that the fob is transmitting then that is the most likely explanation or the container isn't the right one for the key.
I don't think the plastic container was sealed when I got it so you wouldn't know if it had already been opened.
Old May 10, 2022 | 05:37 PM
  #48
a102768's Avatar
Yay, I finally got the fob working. I tried keeping an eye on the battery connectors as I closed the case and realised that the one on the right didn't look like it would actually touch the battery. I did a quick google for images and spotted that it should be vertical not leaning back so it possibly got bent when I first opened the case to see if a battery was fitted.
Unfortunately it snapped off when I tried to bend it back but a soldering iron seems to have stuck it back on again OK and it now locks and unlocks the car!
Old May 11, 2022 | 12:51 AM
  #49
chrzesm's Avatar
5 Year Member
Good you have sorted it out. Thanks for sharing.
Old May 11, 2022 | 01:16 AM
  #50
a102768's Avatar
Thanks. It is quite easy to bend it because that terminal fits into a cutout in the plastic case so if, like me, you are not careful when putting the fob back together the edge of the cutout will catch on the terminal and bend it.
I put the working circuit board into my second crystal key this afternoon so have two fully working fobs now but I may still look around for a proper Aston valet key as I am worried I will drop a crystal key and damage it!
The other option is to look around for a new plastic case and transfer the innards over. I have found a brand new case for just over £100 but does anyone know of a cheaper source?
Old Apr 16, 2023 | 11:03 PM
  #51
Kamrooz Karimi's Avatar
5 Year Member
Kamrooz Karimi is infamous around these parts
Originally Posted by xuledywo
Can you please provide me with more information about what you are referring to and give me some background on the issue?
hey , I accidentally deleted the older key on system
what can I help you with ?
Old Apr 30, 2023 | 04:05 PM
  #52
Captain Cove's Avatar
5 Year Member
Captain Cove is infamous around these parts
I’ve always been afraid of deleting a key by mistake as I don’t have the codes to re program it. My best guess is to get a Volvo key with new codes from the Volvo dealer and program that in them swap the circuit board. Pill stays with the cristal key. I assume you deleted the key fob by mistake and not the pill.
If you deleted the pill by mistake then you need to go through the ford key procedure if you have 2 active keys.
it’s a complicated system, and I’m sure I could explain it better so feel free to ask questions.
robkat
Sep 26, 2019 03:34 PM
dougcayenne
Aug 26, 2019 10:39 AM
porsche-driver
Apr 7, 2012 05:10 PM
steve harris
Aug 2, 2006 07:19 PM
