2019 aston Martin vantage maintenance
Old Nov 29, 2020 | 06:32 PM
Tron's Avatar
Tron is infamous around these parts
Hey did the porterfield R4-S pads still have no brake squealing on your 2019 Vantage? I am having a lot of brake squeal on my 2019 Vantage and looking to get these pads.
Originally Posted by programmatore
Earlier this year I reached out to Rich at @Redpants about the breaks squealing on my 2019 Vantage. Timing was perfect because it just so happened he was working with Porterfield on fitting their R4-S pads on the new Vantage and was looking for testers. I'm glad I signed up because the pads worked -- squealing was gone!
Check it out: https://www.redpants.lol/shop/porter...4-s-brake-pads
Old Nov 29, 2020 | 06:36 PM
Tron's Avatar
@dcarrer0 did the R4-S pads stopped the squealing noise on your 2019 Vantage? Having the squealing issues on mine and looking for a fix.
Originally Posted by dcarrer0
Canceled my order last week since he said they were on backorder. I ordered from Velocityap.com out of California on Saturday. Received them today via Fedex. So not sure on what's going on.
Old Nov 29, 2020 | 06:40 PM
dcarrer0's Avatar
dcarrer0 has much to be proud ofdcarrer0 has much to be proud ofdcarrer0 has much to be proud ofdcarrer0 has much to be proud ofdcarrer0 has much to be proud ofdcarrer0 has much to be proud ofdcarrer0 has much to be proud ofdcarrer0 has much to be proud of
Yes, it sure did. I replaced them on my DB11. Squeal gone and a lot less brake dust.
I replaced them on my 2014 Vantage too. All was gone as well. Couldn't recommend a better set of pads. Easy install too!
Old Nov 29, 2020 | 06:56 PM
Tron's Avatar
Thanks for the quick response! Did you ordered from VelocityAP? I will do it tomorrow, can stand the squealing.
Old Nov 29, 2020 | 06:58 PM
dcarrer0's Avatar
I did. Quick shipment too. Rich kept saying they were on backorder. Velocity had them in stock so not sure what the deal was.
Old Nov 29, 2020 | 08:26 PM
programmatore's Avatar
programmatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond reputeprogrammatore has a reputation beyond repute
Yes. There is no brake squeal whatsoever with the R4-S pads. There is still some brake dust but a little less than OEM. Mind you, I got the prototype R4-S pads from Porterfield/RedPants so YMMV, but I doubt they changed the actual compound. Definitely give them a shot.
One other thing: I've used them on the track -- five 20 minute runs in my group, with 40 minutes in between run groups. No fade, no issues.
Old Nov 30, 2020 | 07:24 AM
Tron's Avatar
Thumbs up
Thanks @programmatore I don't track the car would love to but realistically city driving and some backroads on the weekend. The brake squeal would be the main reason for changing out the pads. I noticed RedPants links were down for the Porterfield so I will go with VelocityAP.
Did you have to go to the AM dealer to get pads swap out? any issues with the brake sensors working on the new pads?
Old Nov 30, 2020 | 12:44 PM
You don't have to go to Aston Martin to get the pads swapped unless you love spending money unnecessarily.
It's a straightforward brake pad swap that any competent shop can perform (you can even do it yourself). The pads are a direct replacement so no issues with wear sensors, etc.
Old Dec 1, 2020 | 06:57 PM
dcarrer0's Avatar
I second that. Very easy. Our E300 was 10 times as hard. Just ridiculous. Used a local mechanic.
Old Dec 2, 2020 | 07:39 AM
Tron's Avatar
Ordered the Porterfield R4-S, will keep you all posted once it's installed...
Old Dec 2, 2020 | 09:31 AM
One last thing: the R4-S pads are progressive without that really strong (obnoxious) bite of the OEM pads. The Vantage doesn't jerk anymore when coming to a complete stop.
Old Dec 15, 2020 | 09:38 AM
Tron's Avatar
Got the R4-S installed, ran it for 300KM, so far so good, no squeal braking and yes smoother braking then OEM. Fingers-crossed this keeps up.
Also noticed that the OEM pads were not grease between the callipers where the pads slides in on all four, got that greased as well.
Old Dec 20, 2020 | 11:13 AM
orangegrower's Avatar
orangegrower is infamous around these parts
Can anybody share the part numbers for the Porterfield pads for both the front and rear on a 2019 Vantage? Thanks
Old Dec 23, 2020 | 07:12 AM
jehu's Avatar
jehu is infamous around these parts
Great info here. I have a' 11 V12 and was wondering if there were any Porterfield pads for this model. Anyone know parts number or website to inquire?
Thanks,
James
got one
Sep 11, 2019 05:55 PM
tko211
Feb 21, 2019 06:01 PM
shinjuku
Jul 22, 2015 08:37 AM
007 Vantage
Nov 9, 2012 02:32 PM
007 Vantage
Oct 25, 2012 02:56 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
