What adhesive to use for loose velcro?
Old Feb 16, 2020 | 01:39 PM
Calcifer33's Avatar
Calcifer33 is infamous around these parts
Hey everyone, while pulling apart the rear seat during a battery replacement, the velcro attached to the underside of the seat came loose from the seat. I am noticing some other velcro coming loose from its permanent placement, as well. I've always wondered what specific kind of adhesive automakers use to join things like velcro to metal or other various surfaces. Any ideas on what to use to get this properly adhered again that won't risk damage to the seat? I expect that hot glue isn't safe. Thanks in advance for sharing your experience.
Old Feb 16, 2020 | 02:53 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Contact cement.
Old Feb 18, 2020 | 05:57 AM
E30 Racer's Avatar
E30 Racer is infamous around these parts
3M makes a very thin double-sided tape (more like a film than tape). It's very thin, and very, very sticky. Kind of a hassle to work but it is extremely effective when applied to clean materials.
Old Feb 18, 2020 | 06:53 AM
Senatorblutarsky's Avatar
Senatorblutarsky is infamous around these partsSenatorblutarsky is infamous around these parts
Gorilla snot
The guys at the Palm Beach Garage use a 3m glue that they call 'Gorilla Snot'. It is green, comes in a tube. I don't know the actual name, but I used it to glue down a corner of my convertible top. Worked like a charm.
Old Jun 1, 2020 | 10:03 PM
Calcifer33's Avatar
Update that contact cement did not work for me. It simply pulled apart instead of the velcro. I'll have to try some of these other options, unless anybody knows specifically what AM or other manufacturers use during original install.
Old Jun 1, 2020 | 10:12 PM
J doubleU's Avatar
New 3m hook and loop AKA velcro.
Old Jun 2, 2020 | 01:57 PM
Calcifer33's Avatar
So you mean new velcro with an already-applied adhesive backing?
Old Jun 2, 2020 | 02:22 PM
J doubleU's Avatar
Old Jun 2, 2020 | 02:49 PM
Calcifer33's Avatar
You rock. That's my next course of action then. Thanks!
Old Jun 3, 2020 | 12:36 PM
E30 Racer's Avatar
In case that doesn't work (I assume it will), the tape I mention in the third post above is "3M 300LSE adhesive transfer tape." Its basically a really, really thin double-sided tape...like VHB but without the foam in the middle. There are bunch of variants, but I can say from direct experience that p/n 9472LE and 9474LE have both worked well for me.
Amazon Amazon
I've used it to re-attach the passenger footwell carpet to the aluminum fusebox cover, the sound insulation on the back side of the inner fender liners, etc. Definitely worth playing around with.
Lars_Tempest
Bentley
44
Oct 19, 2020 06:01 PM
waymegelli
Oct 30, 2018 05:28 AM
ginatom
Cayenne 955/957
17
Mar 30, 2017 01:22 AM
randyb
Jan 31, 2017 10:20 AM
shinjuku
Jul 6, 2015 05:19 PM
