What fluid is this?
Old Jun 5, 2020 | 06:06 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
What fluid is this?
Hi guys
I have 2009 DB9
I noticed this fluid on passenger side I think it’s on AC compressor but it’s quite oily
AC works fine. Compressor may be slightly noise but not very loud.
Old Jun 5, 2020 | 07:13 PM
J doubleU's Avatar
A/C tracer dye, noisy compressor? She may be ready to expire. Clean up the mess to trace where the source is. Have you ever had the system repaired or recharged? Overcharging will set off the pressure valve on the compressor and spray some oil/dye mix out.
Old Jun 5, 2020 | 07:23 PM
No never recharged the AC
AC WORKS ice cold
in this compressor , oil inside compressor is mixed with refrigerant? Or is it two separate compartment e holding Freon and other holding compressor oi?
leaked liquid was oily and green.
my car was recently at dealer and dealer told me compressor is leaking but I am trying to figure out if it’s compressor oil which is leaking or is it Freon?
compressor oil is usually “PAG OIL” or something like that which is usually clear so how did the dealer put dye in the oil?
Old Jun 5, 2020 | 07:45 PM
J doubleU's Avatar
Dye is in the compressor oil (PAG) to identify a leak in the system. You obviously have a leaking compressor. Not a separate thing, it's a combination with the 134a refrigerant. It will eventually leak out and quit blowing cold. Dye is added to the system from new build. You should be shopping for a new compressor replacement.
Old Jun 5, 2020 | 08:23 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
FYI - alibabaexpress has that compressor for $120... Might last, might not!
Old Jun 6, 2020 | 06:12 PM
RBWIII's Avatar
RBWIII is infamous around these parts
+1
found the leak
Old Jun 6, 2020 | 10:25 PM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
I'd be very skeptical about using a $120 Alibaba unit.
Old Jun 6, 2020 | 10:28 PM
I should have tried alibaba one
I had ordered one from eBay canada for $ 800 it seems like it came from some Aston dealer in Canada.
looking at it it seems easy to replace
have to take the belt off
4 long screws come off and I think it comes out
so trying aliexpress in worst case scenario one has to do it again what else can happen beside it fails in short time ?
Old Jun 6, 2020 | 10:31 PM
Kalepsis's Avatar
5 Year Member
I'd be afraid of something that cheap literally falling apart and you end up losing the belt while driving. Bad juju.
But hey, it's just my opinion.
Old Jun 6, 2020 | 10:37 PM
Any one knows if original compressor comes with proper amount of oil or do I need to add oil before installing it ?
Old Jun 7, 2020 | 05:54 AM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Speaking from my 40yr commercial AC tech background . Chances are the compressor will come labelled as to if it needs oil or not and the type required .
However once you have installed the compressor how will you pressure test , properly evacuate and recharge the system with the correct amount of refrigerant .
This is not a DIY job and if done incorrectly that 800$ compressor will by a 2$ paperweight .
Old Jun 7, 2020 | 06:36 AM
There is no label on the compressor talking about oil.
i have a friend with all the tool required to do the job. He had done it on one of his truck before. He has built planes and he thinks we can do it.
vtagrlvr if you can give us some specific pointers would appreciate it. If it turns out we can’t do it properly I can install new compressor and then take the car to one of CAR AC shop and they can do the process of filling refrigerant properly ?
one can drive the car Short distance after new AC COMPRESSOR. as long as we don’t use AC correct?
Old Jun 7, 2020 | 06:43 AM
Thi
s is the label on new AC compressor
Old Jun 7, 2020 | 09:12 AM
Vantagelvr's Avatar
If the AC is still working then chances are it still has some refrigerant in the system . That needs to be recovered before you change the compressor , you cant just vent it to atmosphere .
You need recovery equipment , dry nitrogen, the correct oil and amount , a vacuum pump capable of pulling less than 250 microns , refrigerant gauge manifolds and the knowledge of how to use all the equipment .
Old Jun 7, 2020 | 09:33 AM
J doubleU's Avatar
A/C compressor comes with oil if new from Denso. Reman unit may not. Most guides tell you to drain oil from old compressor, measure. Then drain and refill new compressor with same amount that was removed. Also you should be replacing the receiver dryer at the same time. Oil description is on the tag ND-8 which is Nippon Denso's term for PAG 46 common oil for 134a. Compressor fill amount is 80ml so around 3oz mark. I would make certain it has at least 3oz before fitting. Should have a bolt in the middle of the housing to add or check oil.
