Substitute for AMDS to Bleed Sportshift?
Old Aug 20, 2020 | 09:03 AM
Blacksport350's Avatar
Registered PM
Blacksport350 is infamous around these parts
I have a car with Sportshift 3 and need to replace the actuator. Is there any trick to get around using an AMDS to bleed the hydraulic system afterwards? Maybe an Autel or something similar will get you access?
I think a solid trick to bleeding the clutch circuit (which I don't need to do) is put the car on a lift. Start the engine, engage 1st (or Reverse) and the brake. This will keep constant pressure to the clutch circuit and should allow opening of the bleed screw as needed. I have not tried this but it should work.
I know the Launch X431 is popular with the Ferrari guys and they say they support ASM functions on Aston Martin.
sideboob
Sep 24, 2015 05:09 AM
floatingkiwi
Sep 7, 2014 08:53 PM
BoxsterMac
Jul 31, 2012 12:55 AM
Hella-Buggin'
Jun 22, 2010 09:08 PM
Yves
Apr 11, 2009 12:49 PM
