Windows inoperable
Old Aug 24, 2020 | 09:33 AM
Denny 6.53's Avatar
Denny 6.53 is infamous around these parts
Windows inoperable
Hello everyone,
My car sat for a week + and through self-inflicted error, my battery went completely dead. I put the conditioner on it and it is now back to normal. I have the alarm fault and I am going to replace the module. Today's problem though, is that the windows were down and they now are inoperable. I tried the window reset a number of times, but it is still dead. I tried and failed to open the fuse box under the hood to check the door fuses. I did succeed, however, in breaking one of the tabs towards the firewall.
Suggestions?
Thank you
Old Aug 24, 2020 | 09:40 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
open up the passenger side floorboard fusebox, (under the carpet and a few torx screws to remove the panel) pull both F82, F83 and inspect them... if they seem ok, pop em back in and maybe your windows will work again... I had an issue with my window not working and also the repeater bulb wasn't working so maybe turn your turn signals on to see if they are working or not and if not, that could probably fix the issue like it did for me
Old Aug 24, 2020 | 02:37 PM
Denny 6.53's Avatar
Thank you, Sonies!
Mission accomplished
Old Aug 24, 2020 | 02:41 PM
sonies's Avatar
5 Year Member
nice! glad it worked
randyb
May 2, 2022 02:34 PM
anasu98
Apr 15, 2022 07:37 PM
sinclair
Aug 14, 2011 06:10 PM
bryantjew
Jan 28, 2008 02:57 PM
jimmer23
Feb 4, 2007 07:50 PM
