hood emblem removal
Old Jan 29, 2021 | 09:30 PM
Stucat's Avatar
5 Year Member
Stucat is infamous around these parts
hood emblem removal
Getting my DBS front end protective filmed. Looking on how to remove the Aston Martin hood emblem? Also looking for an Aston Martin carpet set ?
Old Jan 30, 2021 | 07:15 AM
handyman2009's Avatar
Veteran: Canadian Forces
The hood emblem is two way tape holding it, as far as carpet set you can try Andrew @exoticare in Canada, you can search on the forum for his work.
Old Jan 30, 2021 | 07:51 AM
J doubleU's Avatar
If the place doing the PPF doesn't know how to remove the Wings, I would question their job skills.
Old Jan 30, 2021 | 09:28 AM
Stucat's Avatar
5 Year Member
He said double sided tape, just doing my due-diligence and for my knowledge, at 67 years old , you can still teach an old dog a new trick. Fishing line and some WD-40 , or adhesive remover should do the job?
Old Jan 30, 2021 | 10:49 AM
Rjscharer's Avatar
5 Year Member
Rjscharer has a spectacular aura aboutRjscharer has a spectacular aura aboutRjscharer has a spectacular aura about
Be careful. While trying to remove an emblem from my Maserati last year the back and forth motion of the line
scratched the adjoining paint. Try a doubled up piece of dental floss first after warming the emblem with a
hair dryer.
Old Jan 30, 2021 | 10:52 AM
Stucat's Avatar
5 Year Member
Yea was going to tape all around it and bbbbbbbb careful. will do thanks
Old Jan 31, 2021 | 05:59 AM
embdenb's Avatar
As noted in prior post, heat first and continue heating during the removal process.
Old Feb 3, 2021 | 07:05 AM
Aston502's Avatar
Aston502 is infamous around these parts
I'm not sure why you would remove the badge. My PPF has a cut out for the badge.
Old Feb 3, 2021 | 08:31 AM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Agreed, Mine was done without removal...you cant find the cut line around the emblem. I don't like the idea of having a layer of PPF between the badge and the car. Remember, some day I believe the PPF will be removed. Personal preference I guess. Make sure the person applying the PPE is a Pro with a solid reputation !
Old Feb 3, 2021 | 03:04 PM
Stucat's Avatar
5 Year Member
I am changing the emblem also all to all black.
Old Feb 3, 2021 | 04:10 PM
Rjscharer's Avatar
5 Year Member
Just had pdf ppf on my new Vantage. Emblem was left in place..
Old Feb 5, 2021 | 11:18 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
heat gun and some fishing line does the trick, get some automotive goo gone to clean up the mess it leaves afterwards
djloush
Nov 25, 2020 10:01 AM
Prefurbia
Nov 2, 2017 04:33 PM
dicktahoe
Jan 4, 2016 12:25 AM
007JB
Jun 30, 2015 11:53 AM
dicktahoe
Jan 5, 2013 12:21 PM
