Repainted Calipers flushed brake and clutch lines
Old Mar 7, 2021 | 06:12 AM
Julioz32's Avatar
Julioz32 is infamous around these parts
I recently repainted my calipers from silver to Lime essence and flushed the brake and clutch system using Motive brake bleeder.
Which was a good think since a burst of air bubbles was released and improved “smooth” shifting from first to second when cold.
Old Mar 7, 2021 | 06:53 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Did you paint them yourself?
Old Mar 7, 2021 | 10:53 AM
Julioz32's Avatar
No, I removed them and had the paint shop do it. / Tri-coat paint, base, pearl and clear. $350.00
Old Mar 7, 2021 | 11:02 AM
5 Year Member
That sounds quite reasonable. I'd like to do the same at some point. Just had the calipers ceramic coated; so once that wears down then it'll be time.
Old Mar 8, 2021 | 05:29 AM
E30 Racer's Avatar
E30 Racer is infamous around these parts
Looks great, nice change. On a different note, how are you supporting the car in the air (wheels off) while on your 4-post?
Old Mar 8, 2021 | 06:02 AM
Julioz32's Avatar
I have a rolling jack on the lift, so I lift the rear first from the subframe and place jack stands at the rear jack points and than move the rolling jack to the front lift points.
Old Mar 8, 2021 | 07:46 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Did you drain the brake system or block the lines while the calipers were off?
Old Mar 8, 2021 | 12:43 PM
Julioz32's Avatar
blocked with snug vacuum caps on brake lines flare. Do not allow fluid to go below min level in the fluid reservoir.
dblcrwn
Detailing
Mar 29, 2015 09:31 PM
007 Vantage
Feb 19, 2014 01:50 PM
Hella-Buggin'
Jun 22, 2010 09:08 PM
AIRjordan23
May 6, 2006 08:43 PM
