Volvo remote programming codes
Old Mar 17, 2021 | 05:31 PM
mackorbuddy's Avatar
mackorbuddy is infamous around these parts
Hello all,
I have this new Volvo remote with the programming codes. Does anybody here know how to decipher this label? 30772198 is the part number. Is the 16-digit code up top what’s needed for programming? Or the 8 digit code below it? Or both? I’m assuming the right side is all Fs since this package only contained the one key.
I’d just like to know which code is relevant so I can put a little sticker on the transmitter itself in case it ever gets separated from the code.
Thanks all.
Old Mar 18, 2021 | 03:32 AM
chrzesm's Avatar
5 Year Member
chrzesm is infamous around these parts
Here is your code. You need a laptop with AMDS to register your key. Please note your second slot is FF as there is no key attached.
Old Mar 18, 2021 | 04:25 AM
J doubleU's Avatar
Both the 8# and 16# codes are required for programming. You should just have it programmed by a dealer and be done with it.
Old Mar 18, 2021 | 04:46 AM
chrzesm's Avatar
5 Year Member
This is right. Both numbers are required for programming: #8 is the key ID, while #16 is the programming code.
Old Mar 18, 2021 | 08:33 AM
Thank you very much!
Old Mar 28, 2021 | 11:27 AM
SBGRacing's Avatar
SBGRacing is infamous around these parts
Is it possible for a Volvo dealer to program the key? They are many more Volvo dealers around and likely much cheaper for the service.
Steven
Old Mar 28, 2021 | 12:34 PM
J doubleU's Avatar
Buy multiple remotes and have the dealer program all of them for the 1 time cost. Doesn't get any cheaper or easier.
Call Volvo and ask.
Old Nov 14, 2021 | 07:24 AM
czarship's Avatar
czarship is infamous around these parts
Hi all,
I can read RF codes of existing remote control using RF transmitter and receiver module for Arduino BUT I want to read remote control codes from the black chip of the attached circuit and read the RF codes in it using Arduino. please help how can I do it
roku tv remote codes
Old Nov 15, 2021 | 06:20 AM
SBGRacing's Avatar
Originally Posted by czarship
Hi all,
The little black chip is an RF chip however the circuit is a transmitter and you you will need a receiver to see it. The RF chip is needed to start the car and other circuit is for the remote control of the door locks. US and Japan I think use 315 Mhz and Euro uses a higher frequency. Even if you can read it you will need to know what the key expects in order to program it and that is not public information.
Old Dec 13, 2021 | 06:44 PM
czarship's Avatar
Originally Posted by SBGRacing
The little black chip is an RF chip however the circuit is a transmitter and you will need a receiver to see it. The RF chip is needed to start the car and another circuit is for the remote control of the door locks. US and Japan I think using 315 Cannabis Extraction Facility Design Mhz and Euro uses a higher frequency. Even if you can read it you will need to know what the key expects in order to program it and that is not public information.
no response.
Old Dec 14, 2021 | 11:51 AM
Tashakes's Avatar
5 Year Member
Tashakes is infamous around these parts
The ThinkDiag tool will program these, I did mine a couple of months ago.
https://www.6speedonline.com/forums/...rogrammed.html
tommygunn
Sep 8, 2014 10:02 AM
turbo_secret
Nov 28, 2010 05:07 AM
bhart192
Jan 20, 2010 06:32 AM
JSmith5690
Jan 17, 2006 09:15 PM
