Infamous Tail Light Condensation
Old May 25, 2021 | 08:12 PM
V8Vdrew's Avatar
5 Year Member
V8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the rough
Originally Posted by brightoncorgi
I've either read here or was told at the dealership the trick is in the install of the lights. At least if the dealer installs it, there's a 1 year on parts and service if it fails.
I have OEM ones and its hard to imagine that Aston has messed up so many installations not knowing their own torque value. But my plan is to silicone seal all house/lens meeting surfaces and then be careful with tightening.
Old May 26, 2021 | 10:14 AM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Can you imagine what the dealer would charge for new tail lights with a one year warranty. You could probably by 2 or 3 sets for the same cost and install yourself.
Old May 26, 2021 | 05:29 PM
V8Vdrew's Avatar
5 Year Member
Yea I did not even bother asking them after they charged my friend over 3800 for a coolant hose replacement.
Old May 27, 2021 | 04:00 AM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
I have a half-baked idea. Drill two inconspicuous holes. On one side, a screened intake that routes air through a desiccant canister and a check valve. On the other side a small brushless DC fan and another check valve to extract damp air.
Maybe it could be powered by the aft fusebox, via some completely unused fuse location... hmmm...
Must investigate further.
Old May 28, 2021 | 04:30 AM
V8Vdrew's Avatar
5 Year Member
You have got my attention! Do it! Once my new tail lights arrive, I will be messing around with different ideas with my defective one. 1st goal is to figure out how to fix the PCM board and see how easy it is. 2nd goal is to figure out how to vent this taillight.
Bobby Buggs
Jun 17, 2019 12:48 PM
kdm
Apr 22, 2019 06:26 PM
khalid
Jul 2, 2010 10:22 AM
