Checking oil…
Old Jul 18, 2021 | 03:00 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Checking oil…
I have an 207 Vantage. I check the oil at least twice a week. When the car has been sitting for a few hours or day the oil is at the max line on the dipstick. If I follow the directions in the manual the oil is all the way to the op of the flat park of the stick. Well above the max line. How about some advice. Thanks.
Old Jul 18, 2021 | 03:35 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Suck oil out of the top till it's at the correct level. Its been over filled. Mine shows no oil on the dip stick when cold.
Old Jul 18, 2021 | 06:14 PM
J doubleU's Avatar
+1 if your doing it right, they did something wrong previously.
Old Jul 19, 2021 | 05:31 AM
MAUMAU's Avatar
MAUMAU is infamous around these parts
Make sure that after you run the car as per instructions, that you remove the dipstick, wipe it down, and then check the oil. If you do not do this it will appear as if it is overfilled when it is not.
Old Jul 19, 2021 | 01:01 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I hated checking the oil on the V8V. V12 is much easier.
Old Jul 20, 2021 | 05:45 PM
Argus's Avatar
Pumped the oil out it was overfilled by the person I purchased the car from. It just seems weird to check the dip stick and nothing on the thing.
Old Jul 21, 2021 | 01:16 PM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
Not going to lie. I am still perplexed by the oil check procedure and have read the owners manual front to back and that particular section repeatedly. I am easily confused but it seems excessively complex a procedure to check the oil level. 2007 Vantage, 4.3.
Old Jul 21, 2021 | 02:28 PM
5 Year Member
If I had kept the V8V longer, I would've done a walk through on how to check the oil with a tech at the dealership. Perhaps those who are unsure on how to check can do the same?
Old Jul 21, 2021 | 02:52 PM
MRCW's Avatar
dry sump procedures are different, as the oil reservoir is not the oil pan but a separate tank. in order to adequately check the correct volume of oil in the system the engine needs to be run briefly to get all the oil running throughout the engine and then checked immediately after shutting down the engine...
it allows for a lower engine placement, improved CG/ handling, larger oil capacity, but is more complex and expensive.
Old Jul 22, 2021 | 06:40 AM
Marmot's Avatar
5 Year Member
I will be at the dealer on Monday for annual service. I'll ask for a walk through and report back on what I am shown.
Old Jul 22, 2021 | 11:02 AM
5 Year Member
It's an extremely easy procedure. In the owners manual.
Old Jul 22, 2021 | 11:20 AM
Marmot's Avatar
5 Year Member
Mine also shows no oil on the dip stick when cold. This seems to be in accordance with the owners manual as a tutorial.
Old Jul 22, 2021 | 05:15 PM
61mga's Avatar
61mga is infamous around these parts
manufacturers of cars with dry or semi-dry oil reservoirs always find it difficult to explain to their owners how to check their oil. and if they try, owners will still get it wrong...soooo some manufacturers have resorted to putting in dashboard electronic oil level measuring systems that prohibit measurement at certain times. example: i have to wait 30 minutes after i turn off the car (porsche cayman) to get a reading. if the car is cold (a term to be determined by the ECU of course) it will give me a measurement on startup, but don't dare turn off the car or you'll be forced to wait 30 minutes to get a second reading!
embdenb
Oct 17, 2018 10:35 AM
solrac6262
Apr 13, 2016 08:22 PM
Bleen
Dec 16, 2014 08:58 AM
macksamus
Dec 9, 2011 11:29 AM
