Intermittent Starting Issue
Old Sep 28, 2021 | 09:14 PM
Fiesta54's Avatar
Fiesta54 is infamous around these parts
I've tried searching, but I haven't found anyone that is having quite the same problem. I have a 2009 DB9 that occasionally takes quite a few tries to start. Battery tests fine, tried replacing the fob battery. Sometimes the starter will click for a few tries and then all of a sudden crank strong. Other times it will crank strong and then cut out before the car starts. I've noticed the start button is turning white when this happens. It is very inconsistent and I have not been able to see a pattern. Sometimes I need to insert the key 15 times, other times once. It really seems like it suddenly does not recognize that a key is inserted. Thanks in advance for any advice!
Old Sep 29, 2021 | 07:52 AM
I_gotta_Vantage's Avatar
5 Year Member
I_gotta_Vantage is infamous around these parts
Starter solenoid is glazed from heat... it happens to all cars... daily drivers... will need a new starter....
Old Oct 22, 2021 | 03:39 PM
Fiesta54's Avatar
Oops, didn't see your response. After spending a bit more time paying attention to patterns I really believe it is electrical. Sometimes the switch will not turn red. Even going slow with the two finger method. Is it common for the sensor or ignition "cylinder" to go on these?
Old Oct 22, 2021 | 04:07 PM
5 Year Member
I would strongly suggest you have your starter checked. Youre wearing down innocent parts that will cost you more if you are having to cycle the key several times just to get it to start. Should be a 1 to 1 ratio but youre adding additional wear on the key side of the problem....
When the ring lights up, you have just closed the 12v DC loop and now the solenoid which is a coil magnet attached to the starter gets hot every time it's energized because it's supposed to engage the starter and then turn the engine over... 3 seconds max that engagement.... your solenoid has gotten too hot from all the attempted starts and now its so glazed from 10x times from failed starts...
pushing the key all in - the solenoid should instantly engage the starter gears and turn the engine over. 3 seconds max...
The only other thing that comes to mind is your brake switch is tied into the start sequence as well.. its the blue plunger behind your brake pedal.
NigelM
Bentley
24
Jul 12, 2021 04:46 PM
PJK
Apr 6, 2021 04:21 PM
electronaut
Feb 20, 2017 10:11 AM
z06801
Mar 22, 2015 07:00 PM
marcog
Feb 23, 2006 07:11 AM
