OE Replacement PPF - On the Struggle Bus...
Old Feb 14, 2022 | 12:34 PM
Tom_Boy's Avatar
Tom_Boy is infamous around these parts
So, I watched about a gazillion YT video's before buying my first AM. I bookmarked a lot of sites.... I swear I bookmarked a site that offered (OEM?) die-cut PPF replacements for the rear fender/wheel-well. Mine look like French Crackle pottery, and 1 of the pieces is missing. Can anybody point me in the right direction? I have spent like 2 hours searching this AM, and really need to do some legit work.
Thanks-
Tom
Old Feb 14, 2022 | 01:00 PM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
If I'm not mistaken (former Land Rover parts guy) you're looking for what is called the Sill Tape. This diagram from Scuderia should help narrow it down...Not sure I can post a link but...
I think you're looking for 27 and 28.
Old Feb 14, 2022 | 01:06 PM
txtonyo's Avatar
5 Year Member
txtonyo is infamous around these parts
Honestly, you may be better off with an aftermarket brand (XPEL, the usual other suspects) with a warranty. I had to do that with a 911 and it worked out just fine. Same for the DB9, PPF applied on much of the front and changed the pieces in the back so all would match and fit under the PPF warranty.
It is great to do things yourself, however, with this I'd probably let an installer deal with it. Also, you could customize the piece if you wanted a particular size.
Old Feb 14, 2022 | 01:14 PM
Marmot's Avatar
5 Year Member
I one hundred percent agree with having something like Xpel installed professionally so that it all matches and you get a warranty. It will get torn up again. You might as well have everything match and a good paint correction done when you have it taken care of.
Old Feb 14, 2022 | 01:23 PM
txtonyo's Avatar
5 Year Member
Yes, should have added that - remove old pieces, have paint corrected (or at least a good polish to smooth it), then PPF applied, then top coat (ceramic, wax, your favorite) as the top layer.
Old Feb 14, 2022 | 01:24 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
If you desire factory, Aston Martin Bits has it for less cost than Scuderia, but I'd get Xpel dome on a larger area. I had my C8 entire lower area from the front wheel to the rear done in Xpel.
Old Feb 14, 2022 | 04:24 PM
Tom_Boy's Avatar
WOW! Thanks all... Great advice. I spent 10 mins looking @ Scud parts, could not find it. Car was just paint corrected before I bought it... I ended up re-doing it... I don't want to peel the old stuff off until I get the new pieces. Would not mind having a local shop do it for me, but finding one in the area (DFW) and getting the car there for 1/2 day may take it easier for me to do,,, I'll poke around and let y'all know what I decide to do... Thank you again!!!
Tom-
Stebo
Apr 30, 2016 04:39 AM
HIX
Oct 22, 2014 08:49 PM
mrdorkdar
Sep 15, 2013 06:35 PM
jr1966
Jan 20, 2010 07:09 PM
mountainC4
Mar 6, 2007 06:55 PM
