ECU Key Programing
Old Apr 3, 2022 | 10:39 PM
Sir Rothschild's Avatar
Sir Rothschild is infamous around these partsSir Rothschild is infamous around these parts
ECU Key Programing
Hello All,
I'm debating buying a spare ECU Crystal key and having it programmed for my V12V. The question is, are the codes displayed in the attached what is needed for programming? If so, what does the dealer charge to program these keys?
Thanks All
Old Apr 4, 2022 | 06:50 AM
Ale_72's Avatar
Ale_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud ofAle_72 has much to be proud of
I could be wrong but I think I was charged something like 1h work for the programming.
Old Apr 4, 2022 | 06:53 AM
Captain Cove's Avatar
Captain Cove is infamous around these parts
the key codes are on the 1st line and the respective programming codes are on the 2nd line (more digits).
Usually they come in pairs of keys so you need to know if the key you have is the 1st or snd set of numbers.
The you can get ThinkDiag and running it on Android (iOS is buggy). No need to go to the dealer and you can keep the ThinkDiag to read the rest of the car codes.
May be its even cheaper than a dealer to program the key.
Old Apr 4, 2022 | 08:40 AM
Well, this would be a second key that I'm buying online. So not a two-key set. Will that work?
Old Apr 4, 2022 | 09:30 AM
One key is on the blue numbers and the other is with the orange number, that's what new keys usually look like from the dealer.
On ThinkDiag you can read how many keys have been programmed in your car (maximum is 6 keys I think) and you can read which are active and delete the one that are no longer needed.
Then you program the new one with the codes you got with the new key.
Hope this help clarify.
File Type: pdf
Old Apr 4, 2022 | 09:32 AM
Got it! Thanks so much for the help!!
Ashman_E
Jan 8, 2022 12:44 AM
rhart6
May 10, 2016 07:53 PM
gircal
Dec 1, 2012 06:10 PM
myturbo2
Cayenne 955/957
Jul 13, 2012 09:05 AM
bbywu
Mar 26, 2007 10:50 AM
