Center console swap
Old Apr 14, 2022 | 07:53 PM
Captain Cove's Avatar
Captain Cove is infamous around these parts
Center console swap
Hi,
has anyone tried to swap the center console between 2009-2014 cars? Does it need any AMDS programming? See in pic what I’m trying to swap. There seems like 2 modules that can hold some car specific programming. One is dealing with the buttons and has two connectors with lots of pins and the other module (display) has one connector with ~10pins and one connector with 2 orange optical fibres. Can all that be swapped without reprogramming?
Old Apr 14, 2022 | 08:41 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
That looks like a project..can’t answer..but I’m sure someone will…best of luck with it..
Old Apr 15, 2022 | 01:26 AM
MRCW's Avatar
What are you hoping to accomplish?
Old Apr 15, 2022 | 06:08 AM
Either
a) Do I need to keep the original modules from the original console and swap them on the new one or can I just plug and play the new console?
b) How to reprogram these modules without AMDS?
F
Old Apr 15, 2022 | 06:32 AM
J doubleU's Avatar
Switch the modules over, to keep them car specific. How to program without AMDS, could only be done in a science fiction film.
Old Apr 15, 2022 | 06:37 AM
Yes, quite aware of the science fiction aspect.
Do you know for certain it won’t work and if that applies to both modules. I assume the portion holding the buttons does not have to swap.
Old Apr 15, 2022 | 06:54 AM
J doubleU's Avatar
The upper module is Infotainment so it may be different with options, like Sirius fitted or not. 2014 has Garmin navigation so that may or may not work with the Volvo system in 2011. Plug the newer one in and see what happens, doubt you could hurt anything. Make sure to have the battery disconnected during module switching.
Old Apr 15, 2022 | 01:11 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Move your modules over. It's not that hard to do. I actually stripped my console down to laminate it with carbon fiber, which required me to remove everything. I know you are trying to avoid this path but this is not that hard to do.
Old Apr 17, 2022 | 11:59 AM
Sir Rothschild's Avatar
Sir Rothschild is infamous around these partsSir Rothschild is infamous around these parts
After you're done. If you have an extra Joystick module that still functioning, DM me. I'll buy it off of you.
powderjay
Nov 7, 2019 03:51 PM
tomb18
Apr 2, 2014 03:24 PM
fbroen
Mar 23, 2012 08:04 PM
wowgogs
Mar 7, 2009 09:03 PM
jsdkms
Nov 3, 2007 06:58 AM
