4.3 liter oil bypass filter cover plate replacement hex bolts?
Old May 19, 2022 | 07:36 AM
Slick 6MT's Avatar
Slick 6MT is infamous around these parts
Exclamation 4.3 liter oil bypass filter cover plate replacement hex bolts?
I have everything I need for the oil change aside from these bolts. Does anyone have the specs on these so I can stop by Home Depot on my way home from the office before I tackle the service? Fingers crossed that the torx bolts come out easy and they’ll go straight to the trash. Thanks fellas!
Old May 19, 2022 | 08:42 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Likely 6 mm
I thought I had documented the size in an earlier post, but after a frustrating search to find my original post , I was remiss and didn't include the size; see post #9:
https://www.6speedonline.com/forums/...torx-bolt.html
Annoyed at my lapse, and finally realizing the key search terms were "bypass filter", I found part of the answer in Vantagelvr's post #1:
https://www.6speedonline.com/forums/...il-change.html
From the picture, guessing a 20mm length?
Hope you don't experience any removal issues...
Old May 19, 2022 | 10:01 AM
MRCW's Avatar
Makes sure you use a compatible material screwing into the aluminum housing!
Jasonbrand57
Bentley
May 20, 2022 05:07 PM
droffsite
Apr 3, 2021 09:46 PM
MrRobot
Apr 25, 2017 09:50 AM
Vantagelvr
Dec 27, 2014 07:41 PM
Abby997TT
Jun 22, 2010 05:10 PM
